Weather Monitoring using Rain sensor and DHT11
This project combines the use of the DHT11 sensor along with the FC-37 Rain sensor to monitor and record weather-related data, including temperature, humidity, and rainfall. By leveraging the two sensors and interfacing them to the EzloPi device, we can set thresholds for different scenarios and trigger alarms and acquire and monitor real-time data which can be used for various applications, such as agriculture, environmental monitoring, and smart home automation. The real-time data can be monitored remotely with the use of the MiOS application for both the web and mobile platform.
  • LM393 comparator IC module.
  • FC-37 rain sensor module.
  • DHT11 Sensor.
The wiring diagram for ESP32 30 pins is represented as follows:
From ESP32 (32 pins) to the LM393 module:
  • From ESP32 (32 pins) to the LM393 module:
  • From ESP32 (30 pins) to the LM393 comparator module:
  • Connect the VCC of the ESP32 with the VCC of the LM393 module.
  • Connect the GND pin of the ESP32 to the GND pin of the LM393 module.
  • Connect the ESP32 GPIO 33 to the A0 of the module.
From the LM393 module to the Rain Sensor:
  • Connect any of the output pins of the rain sensor to the positive and negative terminal of the comparator module respectively.
From ESP32 to the DHT11:
  • Connect the 5V Pin from the ESP32 to the VIN, positive (+) terminal of the sensor.
  • Connect the GND Pin of the ESP32 to the GND, negative (-) terminal of the sensor.
  • Connect the IO4 Pin of the ESP32 to the OUT Pin of the sensor.
3. Interfacing the DHT11 sensor and the FC-37 Rain sensor using the EzloPi Web Flasher:
Dimmable LED
Click Connect
  2. In the Device Configuration, tab click on One Wire.
Interfacing the FC-37 Rain sensor using the EzloPi Web Flasher:
  1. In the Device Configuration, tab click on Analog Input.
7. An Analog Input window will open for inputting the following parameters:
  • Set a device name of your choosing. In our case, we set it to Rain Sensor.
  • Set device subtype to Water leak Sensor.
  • Set the ADC input pin to 33.
  • Set the Resolution to 10-bit.
  • Now Click the Apply button.
Interfacing the DHT11 sensor using the EzloPi Web Flasher:
6. In the Device Configuration, tab click on One Wire.
7. A pop up window will open for inputting the following parameters.
  • Set a device name of your choosing. In our case we set it to DHT11.
  • Set Out GPIO to 4.
  • Select The Device Subtype as the sensor you are choosing, we set it to DHT11 Temperature Humidity Sensor.
8. A window will appear on the bottom right side of the screen displaying “Please press BOOT button while flashing begins.”
9. Hold the BOOT button down until the next window appears on the bottom right side of the screen which says “Installation prepared. Please release the boot button now.”
4. MiOS App
Google PlayApple App Store
MiOS Installed App
MiOS Login
Controllers Connected
  1. After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device.
  2. As you can see in the example given above, we can see the rain sensor tile. It shows a “No Leak” message on the tile as the sensor is not detecting any raindrops or rain water. The DHT11 sensor tile is also visible which is displaying the temperature and humidity values.
5. MiOS Web Application
Login To MiOS
  1. After opening the MiOS web dashboard, you will be able to see the tile of your connected device. In the above figure, the voltmeter/voltage sensor tile is displaying the voltages being measured by the sensor of the connected battery.
Buy Components
