Get an email alert to keep your environment just right!
Water quality alert using Turbidity sensor and EzloPi MeshBot
The objective of this project is to interface the TS-300B turbidity sensor with the EzloPi device for creating a smart water quality monitoring system. This project is designed to detect changes in water turbidity and, upon detecting an increase in impurities, it will trigger an automated email to the user through the EzloPi automation meshbot. The turbidity sensor will detect impurities and alert the user through email or the MiOS application to replace the water filter.
2. Project Video Demonstration
Welcome to the project demonstration video section. The following video showcases the key aspects of Create your own smart Turbidity Sensor using EzloPi Platform, providing a visual walkthrough of its implementation.
- LM393 photo-resistive LDR module.
From ESP32 to the Turbidity sensor interface module:
- Connect the 3V3 pin from ESP32 to the VCC terminal on the turbidity sensor interface module.
- Connect GND to the GND pin.
- Connect D33 from the ESP32 to the signal (Dout) pin.
From the Interface module to the Turbidity sensor:
- Connect the given cable from the interface module to the turbidity sensor.
4. Interfacing the Turbidity sensor with EzloPi Web Flasher
Click Connect.
- An analog Input window will open for inputting the following parameters:
- Set a device name of your choosing. In our case, we set it to Turbidity.
- Set Device Subtype to Soil Turbidity Sensor.
- Set the ADC input pin to 33.
- Set the Resolution to 10-bit.
- Then click Apply Button.
5. MiOS Web Application
- If the water is pure or has a low amount of impurities, “water filter ok” message will be displayed. And if the water is impure or impurities have increased, a message such as “replace water filter” will be displayed on the sensor tile.
Meshbots
- After clicking on Create new MeshBot you will see this now under Automation MeshBot click on Cloud.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Turbidity.
- Set Node Type to Device.
- Set the Node to Turbidity.
- Set the Capability to Water filter replacement alarm.
- Set the Value to replace_water_filter.
- Set Controllable Type to Notification.
- Set the User to Your user account but in our case the user account is Tayyab.
- Set the Channels to email, push.
- Set the Subject to Water filter replacement alarm.
- Set the Message body info to replace the water filter.
- On the MiOS web dashboard, we can see the turbidity sensor tile which is showing us the “water filter ok” message which means that the quality of water is clear. In this scenario, email will not be sent to alert the user.
- When the water is not clear or impurities have increased, the tile will display the ”replace water filter” message and the user will receive an email. In this scenario, an email is generated to the user’s gmail account which can be seen below.
6. MiOS App
- After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device. As you can see in the MiOS mobile app dashboard, it can be seen that the turbidity sensor tile is showing the “water filter ok” message which means that the quality of water is clear.
