Water level detection using P45 float switch
Before moving into this example, it is very important to know about the device registration, provisioning and converting the ESP32 device into an EzloPi device along with knowledge of config.ezlopi.com Web Flasher, MiOS Mobile Application for Android/iOS and the MiOS Web Application.
This project aims to interface a P45 float switch with the EzloPi device for efficient water level detection. The P45 float switch is a simple yet effective liquid level sensor, which is integrated with the EzloPi device to enable real-time monitoring of water levels in various applications for users. This smart monitoring is done by utilizing the MiOS smart platform for allowing the users to monitor and notify them about various water level conditions.
The float switch, when interfaced with the EzloPi device, can have many applications for smart automation purposes such as it can accurately detect water levels in tanks for management of water resources. It can also monitor water levels for triggering the operation of motors such as pumps or valves, for optimal water usage and preventing overflow or shortages. And, in industrial applications, the float switch can be used to monitor liquid levels in tanks or reservoirs, facilitating process automation and ensuring efficient utilization of resources.
2. Project Demonstration Video - Float Switch Connection
Welcome to the project demonstration video section. The following video showcases the key aspects of Water level detection using P45 float switch, providing a visual walkthrough of its implementation.
3. Circuit Diagram & Interface - Water Level Float Switch Wiring Diagram
- P45 float switch.
The water level float switch wiring diagram of ESP32 30 pin is represented as follows:
The following Float Switch connections are made in order to complete the circuit setup:
From ESP32 to the Float Switch:
ESP32 | Float Switch |
GND | 1st terminal |
D5 | 2nd terminal |
4. Interfacing the float switch with the EzloPi Web Flasher
Click Connect
- If you are new to this and it's your first time configuring, select Create new Device ID. Click on the Configure Wifi button. Enter Wifi SSID and Wifi Password.
- Set a device name of your choosing. In our case we set it to Float Switch.
- Set the Input GPIO to 5.
- Set Device Subtype to Float Switch.
- Set Default Value to LOW.
- Now Click the Apply button.
5. MiOS App
- After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device.
- As you can see in the MiOS mobile dashboard, we can see the float switch tile. When the water level is below the threshold which is set for the float switch, the tile will display “water level ok” message and when the water level increases and rises above the specific threshold, the tile will display “water level above high threshold” message.
5. MiOS Web Dashboard
- After configuring the controller with the EzloPi web flasher, head to https://ezlogic.mios.com/
- Now, on the MiOS web dashboard, you will be able to see the tile for the float switch.
- When the water level is below the threshold which is set for the float switch, the tile will display “water level ok” message and when the water level increases and rises above the specific threshold, the tile will display “water level above high threshold” message.
