Harness the power of Built-in Hall effect sensor of the EzloPi device!’
Water Leak Detector and Alarm using meshbot
The project aims to create a smart water leak detection and alarm system by interfacing the SEN 18 water leak sensor and a buzzer with the EzloPi device. When a leak is detected by the sensor, the buzzer will be triggered, alerting the user to the presence of water. The system provides early detection of water leaks, minimizing potential damage to property. Users can remotely monitor and control the water leak detection system through the MiOS applications.
- SEN 18 Water Leak Sensor.
- Buzzer module.
From ESP32 to SEN18 Water leak sensor:
- Connect 3V3 from the ESP32 to the VCC of the sensor.
- Connect GND from the ESP32 to the GND pin of the sensor.
- Connect D2 from the ESP32 to the pin “S” of the sensor as an input.
From ESP32 to the Buzzer:
- Connect the D4 pin from the ESP32 to the Signal (I/O) pin of the buzzer.
- Connect the 3v3 from the ESP32 to the VCC of the Buzzer
- Connect the GND to the negative pin of the buzzer.
4. Interfacing the SEN18 Water Leak Sensor with Buzzer using EzloPi Web Flasher
Click Connect.
- Set a device name of your choosing. In our case, we set it to Water Leak with Buzzer.
- Set Device subtype to Water Leak Sensor.
- Set OUT GPIO to 32.
- Set Resolution to 10-bit.
- Now Click the Apply button.
- Set a device name of your choosing. In our case, we set it to Buzzer.
- Set Device subtype to Relay.
- Set OUT GPIO to 4.
- Set Resistor to PULL UP.
- Set the default value to LOW.
5. MiOS Web Application
- Now, on the MiOS web dashboard, you will be able to see the tiles for the Water Leak Sensor and Buzzer. These tiles will indicate the status of the Buzzer depending on the water being detected by the sensor.
MeshBots
- After clicking on Create new MeshBot you will see this now under Automation MeshBot click on Local.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test001.
- Set these values in TRIGGER section:
- Set Node Type to Device.
- Set the Node to Water Leak Sensor.
- Set the Capability to Water leak alarm.
- Set the value to water_leak_detected
- Click on TRUE.
- Set Controllable Type to Buzzer.
- Set the Capability Type to switch.
- Set the Value to true.
- Set Action to immediately.
- Now Click on FALSE.
- Set the Value to false.
- Now Click the Save button.
- Here in the MiOS web dashboard, you can see that when the Water is detected by the sensor. The Buzzer turns on because of the rules we have set in meshbot.
6. MiOS App
- Here, as seen on the MiOS mobile dashboard, when the Water Leak Sensor gets triggered, it turns the Buzzer on because of the rules we have set in meshbot.
- Here, as seen on the MiOS mobile dashboard, when the Water Leak Sensor does not detect any leakage, it turns off the Buzzer because of the rules we have set in meshbot.
