Voltage monitoring of a battery
This project has demonstrated a voltage monitoring setup by utilizing a B179 voltage sensor and interfacing it with the EzloPi device which aims to develop a system that can accurately and continuously monitor the voltage levels of a battery. B179 Voltage Sensor is an essential tool for industries and applications reliant on batteries. It ensures the efficient use of battery resources, reduces downtime, and contributes to the overall reliability of the systems it is integrated into.
Battery voltage monitoring is essential in various applications, such as battery-operated portable devices, renewable energy systems, electric vehicles, and backup power supplies, to ensure the optimal performance and longevity of the batteries. We can als remotely check the battery voltage using the MiOS application.
  • B179 Voltage Sensor Module (0 to 25V DC)
  • Two or more 9V batteries.
The wiring diagram for ESP32 is represented as follows:
  • Connect the GND from the ESP32 to the GND of the voltage sensor.
  • Connect the D33 pin from the ESP32 to the pin ‘S’ of the voltage sensor.
  • No need to connect the ‘+’ pin of the voltage sensor to the ESP32
3. Interfacing the B179 voltage sensor using the EzloPi Web Flasher:
Dimmable LED
Click Connect
  2. In the Device Configuration, tab click on Analog Input.
7. An Analog Input window will open for inputting the following parameters:
  • Set a Device Name of your choosing. In our case, we set it to Voltage Measurement.
  • Set Device Subtype to Shunt voltmeter.
  • Set the IN GPIO to 33.
  • Set the Resolution to 10 bits.
  • Now Click the Apply button.
8. A window will appear on the bottom right side of the screen displaying “Please press BOOT button while flashing begins.”
9. Hold the BOOT button down until the next window appears on the bottom right side of the screen which says “Installation prepared. Please release the boot button now.”
4. MiOS App
Google PlayApple App Store
MiOS Installed App
MiOS Login
Controllers Connected
  1. After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device. In the above figure, the voltmeter/voltage sensor tile is displaying the voltages being measured by the sensor of the connected battery.
5. MiOS Web Application
Login To MiOS
  1. After opening the MiOS web dashboard, you will be able to see the tile of your connected device. In the above figure, the voltmeter/voltage sensor tile is displaying the voltages being measured by the sensor of the connected battery.
Buy Components
