Make smart projects easier with EzloPi
Visual level detection using ADXL335
This project for visual level detection using the GY-61 ADXL335 accelerometer with the EzloPi device aims to measure the tilt or orientation of a surface. The ADXL335 is a 3-axis accelerometer that detects motion and changes in inclination. By interfacing it with the EzloPi device, the sensor’s analog signals are read and processed to determine the angle of tilt along the X, Y, and Z axes. This data can be used for applications like balancing, leveling, or orientation measurement in projects requiring accurate tilt detection. The visual output is displayed on an LED to provide visual indication.
Welcome to the project demonstration video section. The following video showcases the key aspects of Visual level detection using ADXL335, providing a visual walkthrough of its implementation.
- GY-61 3-axis Accelerometer.
- LED with 120 Ohm Resistor
From ESP32 to the GY-61:
ESP32 | GY-61 |
VIN | VIN |
GND | GND |
D25 | Zout |
D33 | Yout |
D32 | Xout |
From ESP32 to the LED & Resistor:
ESP32 | LED | Resistor |
D15 | - | Terminal 1 |
GND | Cathode | - |
- | Anode | Terminal 2 |
4. Interfacing the GY-61 3-axis accelerometer & LED with the EzloPi Web Flasher:
Click Connect
- An Other Input window will open for inputting the following parameters:
- Set a Device name of your choosing. In our case, we set it to GY-61 3-Axis Accelerometer.
- Set Device Subtype to GY61 3-Axis Accelerometer.
- Tick mark the box of GPIO1 and Set the GPIO1 to 25.
- Tick mark the box of GPIO2 and Set the GPIO2 to 32.
- Tick mark the box of GPIO3 and Set the GPIO3 to 33.
- Then Click Apply Button.
- Set a Device name of your choosing. In our case, we set it to the LED.
- Set Device Subtype to LED.
- Set the OUT GPIO to 15.
5. MiOS Web Dashboard
- Here, on the MiOS web dashboard, you will be able to see the tiles of connected devices. In our case we have two visible tiles for GY-61 sensor which are of Y-axis and Z-axis respectively whereas there is a tile for LED also. The LED tile will indicate the stability of the Z-axis.
MeshBots:
- After clicking on Create new MeshBot, you will see this now under Automation MeshBot click on Cloud.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test001.
- Set Node Type to Device.
- Set the Node to GY-61 3-Axis Accelerometer.
- Set the Capability to parent_abstract.
- Set the variables to uuid.
- Set the Comparator to Equal (==).
- Set the value to 0.
- Set the Controllable to LED.
- Set the Capability to power_command.
- Set the Value Type to set.
- Set the value to true.
- Now Click the Save button.
- Now in the MiOS web dashboard, we can see the values of Y-axis and Z-axis and also the tile of LED. For now, the LED does not turn ON because the Z-axis is not stable at 0 which is set in the meshbot settings.
- Now in the above picture, we can see that the value of the Z-axis is stable at 0 so the LED turns ON because of our setting of meshbot.
6. MiOS App
- Here, as seen above on the MiOS mobile dashboard, we can see the values of Y-axis and Z-axis and also the tile of LED. For now, the LED does not turn ON because the Z-axis is not stable at 0 which is set in the meshbot settings.
- Now in the above picture, we can see that the value of the Z-axis is stable at 0 so the LED is turned ON because of our setting of meshbot.
