Smart implementation with EzloPi
Visual current monitoring using LEDs
This project utilizes the ACS712TELC-05B current sensor module interfaced with the EzloPi device to measure real-time current flow in a circuit. The ACS712 provides precise analog current readings, which are processed by the EzloPi to trigger visual indicators. LEDs are used as visual cues to represent different current levels—such as green for normal operation, yellow for warning thresholds, and red for overcurrent conditions. This setup ensures an intuitive, real-time monitoring system for electrical loads, offering a simple yet effective solution for current visualization and fault detection.
- ACS712TELC-05B current sensor module.
- 3 LEDs with 120 Ohm resistors.
From ESP32 to the ACS712 Current sensor:
| ESP32 | ACS712 |
| VCC | VIN |
| GND | GND |
| OUT | D33 |
From ESP32 to the LED1 & Resistor1:
| ESP32 | LED1 | Resistor1 |
| D15 | - | Terminal 1 |
| GND | Cathode | - |
| - | Anode | Terminal 2 |
From ESP32 to the LED2 & Resistor2:
| ESP32 | LED2 | Resistor2 |
| D4 | - | Terminal 1 |
| GND | Cathode | - |
From ESP32 to the LED3 & Resistor3:
| ESP32 | LED3 | Resistor3 |
| D5 | - | Terminal 1 |
| GND | Cathode | - |
4. Interfacing the CS712 Current Sensor & 3 LEDs with the EzloPi Web Flasher:
Click Connect
- Set a Device Name of your choosing. In our case, we set it to Current Sensor.
- Set Device Subtype to CS718TELC 05B Current Sensor.
- Set the ADC input pin to 33.
- Set the Resolution to 10-bit.
- Then Click Apply Button.
- Again, In the Device Configuration, tab click on Digital Output
- Set a Device name of your choosing. In our case, we set it to the LED 1.
- Set Device Subtype to LED.
- Set the OUT GPIO to 15.
- Again, In the Device Configuration, tab click on Digital Output.
- Set a Device name of your choosing. In our case, we set it to the LED 2.
- Set the OUT GPIO to 4.
- Set a Device name of your choosing. In our case, we set it to the LED 3.
- Set the OUT GPIO to 5.
- Now press the Flash Device Button.
5. MiOS Web Dashboard
- On the MiOS web dashboard, you will be able to see the tiles of connected devices. In our case, we have tiles for the current sensor and three tiles for LEDs to indicate different levels of current being measured.
MeshBots:
- After clicking on Create new MeshBot, you will see this now under Automation MeshBot click on Cloud.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test011.
- Set Node Type to Device.
- Set the Node to Current Sensor.
- Set the Capability to parent_abstract.
- Set the variables to uuid.
- Set the Comparator to Greater (>).
- Set the value to 0.1.
- Set the Controllable to LED 1.
- Set the Capability to power_command.
- Set the Value Type to set.
- Set the value to true.
- Again Click on Create new Meshbot and under Automation MeshBot click on Cloud.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test012.
- Set the value to 0.2.
- Set the Controllable to LED 2.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test013.
- Set these values in the TRIGGER section.
- Set the value to 0.3.
- Set the Controllable to LED 3.
- Now Click the Save button.
- Here, you can see your saved MeshBot. Now click on Dashboard.
- Now in the MiOS web dashboard, we can see the value of the current sensor and also the tiles of 3 LEDs. Here, we want to indicate certain thresholds of current by turning ON the LED 1 only, this logic is made in the meshbot.
- Now in the above picture, we can see that when the value of current is above a certain value then two LEDs turn ON because of our meshbot settings.
- Here in this picture, we can see that when the current sensor value is above a certain level then all three LEDs turn ON because of our setting of meshbot.
6. MiOS App
- Here, as seen above on the MiOS mobile dashboard, we can see the value of the current sensor and also the tiles of 3 LEDs. Here, we want to indicate a certain level of current threshold by turning ON the LED 1 only, this logic is made in the meshbot.
