Intelligent response to unexpected events for your home!
Vibration/shock detection by using KY-002 shock sensor module
The goal of this project is to integrate a KY-002 shock sensor module with the EzloPi device, enhancing its capabilities by adding real-time shock detection functionality and ensuring that each vibration is converted into useful data, offering a unique aspect to home automation.. This combined system will enable users to monitor and respond to sudden impacts or vibrations in the environment. Whether you're looking to increase security, turning your space into a dynamic and responsive environment or create interactive scenarios triggered by motion, EzloPi provides a versatile and convenient solution.
Welcome to the project demonstration video section. The following video showcases the key aspects of Vibration/shock detection by using KY-002 shock sensor module, providing a visual walkthrough of its implementation.
The following components are required for interfacing using the EzloPi device:
- KY-002 Vibration tilt sensor module.
From ESP32 to the Vibration Switch Module:
| ESP32 | KY-002 |
| 3V3 | VIN |
| GND | GND |
| D5 | S |
3. Interfacing the Vibration Sensor Module with the EzloPi Web Flasher
Click Connect.
- Set a device name of your choosing. In our case we set it to Vibration Sensor.
- Set device Subtype to Vibration Sensor
- Set Digital input pin to 5.
- Then Click Apply Button.
4. MiOS App
- After opening the MiOS mobile app dashboard, you will be able to see the tile of your connected device.
- Here, as you can see, the sensor tile is displaying a message as “No Motion” when vibrations are not detected by the sensor.
- Similarly, when it detects the vibration, “Motion” appears on the tile.
5. MiOS Web Application
- After opening the MiOS web dashboard, you will be able to see the tile of your connected device.
- When the sensor detects vibrations, “Motion” appears on the tile as can be seen above.
