Secure your smart environment
Vibration-sensitive alarm system
The vibration-sensitive alarm system project integrates the reed switch module, vibration sensor module, and buzzer with the EzloPi device to detect and alert users of unusual vibrations or movements. The LM393 module detects vibrations, triggering the buzzer to sound an alarm, while the KY-025 Reed switch serves as an additional safety feature, detecting if doors or windows are opened unexpectedly. This dual-sensor system enhances security by providing immediate auditory alerts for unauthorized access or unusual movements, making it suitable for securing valuable assets, doors, and sensitive installations.
Welcome to the project demonstration video section. The following video showcases the key aspects of Vibration-sensitive alarm system, providing a visual walkthrough of its implementation.
- KY-025 Reed switch module.
- LM393 vibration sensor module.
- MH-FMD buzzer.
From ESP32 to the KY-025 Reed Switch Module:
| ESP32 | KY-025 |
| VIN | +(VCC) |
| GND | G(GND) |
| D13 | D0 |
From ESP32 to the LM393 Vibration Sensor Module:
| ESP32 | Vibration Sensor |
| VIN | +5V |
| GND | GND |
| D12 | D0 |
From ESP32 to the Buzzer:
| ESP32 | Buzzer |
| VCC | 3V3 |
| GND | GND |
| I/O | D15 |
4. Interfacing the Reed Switch & Vibration Sensor with Buzzer with the EzloPi Web Flasher:
Click Connect
- A Digital Input window will be opened for inputting the following parameters:
- Set a Device Name of your choosing. In our case, we set it to Reed Switch.
- Set the INPUT GPIO to 13.
- Set Device Subtype to Reed Switch.
- Set the Resistor to PULL DOWN.
- Then Click Apply Button.
- Set a Device Name of your choosing. In our case, we set it to Vibration Sensor.
- Set the INPUT GPIO to 12.
- Set Device Subtype to Vibration Sensor.
- Set a Device name of your choosing. In our case, we set it to the Buzzer Alarm.
- Set Device Subtype to LED.
- Set the OUT GPIO to 15.
5. MiOS Web Dashboard
- Now in the MiOS web dashboard, you will be able to see the tiles of connected devices. In our case we have a reed switch, vibration sensor and buzzer alarm tiles. The buzzer alarm will indicate the status of reed switch and vibration sensors depending on the meshbot conditions.
MeshBots:
- After clicking on Create new MeshBot, you will see this now under Automation MeshBot click on Cloud.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test010.
- Set Node Type to Device.
- Set the Node to Vibration Sensor.
- Set the Capability to motion_sensor.
- Set the variables to status.
- Set the Comparator to Equal (==).
- Set the value to true.
- Set the Controllable to Buzzer Alarm.
- Set the Capability to power_command.
- Set the Value Type to true.
- Now Click the Save button.
- Here, as seen above, we can see that when the vibration sensor senses some motion or movement, the buzzer Alarm turns ON because of the conditions we have set in the meshbot.
6. MiOS App
- In the MiOS mobile dashboard, you will be able to see the tiles of connected devices. In our case we have a reed switch, vibration sensor and buzzer alarm tiles. The buzzer alarm will indicate the status of reed switch and vibration sensors depending on the meshbot conditions.
