Feel the vibrations with EzloPi!
Vibration detection using SW180P vibration sensor
After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device. We can see the pressure/force being exerted to the sensor by using the MiOS smart platform. EzloPi smart device effortlessly interprets vibrations, transforming your space into a dynamic, responsive environment. EzloPi smart device turns your place into a smart, dynamic hub where every move counts.
With the EzloPi meshbot automation, users can receive alerts and emails regarding the conditions which have been set. In this project, the user will receive an email alert on his smartphone whenever the sensor detects vibrations or any motion.
Welcome to the project demonstration video section. The following video showcases the key aspects of Get notified when vibration detected using SW180P sensor on EzloPi Platform, providing a visual walkthrough of its implementation.
The following components are required for interfacing using the EzloPi device:
- ESP32 as EzloPi smart device.
- LM393 vibration sensor module.
The wiring diagram for ESP32 is represented as follows:
From ESP32 to the Vibration Sensor Module:
| ESP32 | Vibration Sensor |
| 3V3 | VCC |
| GND | GND |
| D5 | D0 |
4. Interfacing the Vibration sensor module with EzloPi Web Flasher
Click Connect.
- An Digital Input window will open for inputting the following parameters:
- Set a Device Name of your choosing. In our case we set it to Vibration Sensor.
- Set Device Subtype to Vibration Sensor.
- Set Digital input pin to 5.
- Now Click the Apply button.
5. MiOS Web Application
- In the dashboard, you can also see the tile labeled as vibration sensor, which is showing “No motion” on the tile.
Meshbots
- After clicking on Create new MeshBot you will see new option, now under Notification MeshBot click on Create.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test001.
- Set these values in TRIGGER section:
- Set Node Type to Device.
- Set the Node to Vibration Sensor.
- Set the Capability to Motion.
- Set the Value to True.
- Set Controllable Type to Notification.
- Set the User to Your user account .
- Set the Channels to email,push.
- Set the Subject to Movement Alert.
- Write the suitable Message body that you want to receive in your email. As you can see, we write, Some Movement has been detected.
- As we can see we have received email through the Meshbot when movement is detected by the vibration sensor.
6. MiOS App
- After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device. Here, as you can see in the MiOS mobile app dashboard, the vibration sensor tile shows the “No Motion” message.
- As we can see, we have received email through Meshbot when any movement is detected by the vibration sensor.
