Vibration detection by using SW180P sensor and LED indicator
Create a safe environment with EzloPi!
The goal of this project is to integrate the vibration sensor module with the EzloPi device and also interface LED to provide visual indication, enhancing its capabilities by adding real-time vibration detection functionality and ensuring that each vibration is converted into useful data as in this case a visual aid in the form of the LED, offering a unique aspect to home automation. This combined system will enable users to monitor and respond to sudden impacts or vibrations and motion in the environment. Whether you're looking to increase security, turning your space into a dynamic and responsive environment or create interactive scenarios triggered by motion, EzloPi provides a versatile and convenient solution.
The following components are required for interfacing using the EzloPi device:
  • Vibration sensor module SW-180P.
  • 100 Ohm resistor
From ESP32 to the Vibration sensor module:
ESP32 Vibration sensor
3V3 VIN
GND GND
D5 D0
From ESP32 to the LED & Resistor:
ESP32 LED Resistor
D4 Anode –
NA Cathode 1st terminal
GND – 2nd terminal
3. Interfacing the MQ3 Alcohol sensor module with EzloPi Web Flasher:
Click Connect.
  2. In the Device Configuration, tab click on Digital Input.
  1. A Digital Input window will open for inputting the following parameters:
  • Set a device name of your choosing. In our case we set it to Vibration Sensor.
  • Set device Subtype to Vibration Sensor.
  • Set Digital input pin to 5.
  • Now Click the Apply button.
  1. Again in the Device Configuration, tab click on Digital Output.
  1. A Digital output window will open for inputting the following parameters:
  • Set a Device name of your choosing. In our case we set it to LED.
  • Set Device Subtype to LED.
  • Set Digital Output pin to 5.
  • Set Resistor to PULL UP.
  1. After clicking the apply button you can see a table of your setting below in the Current configuration tab.
  2. Hold the BOOT button down until the next window appears on the bottom right side of the screen which says “Installation prepared. Please release the boot button now.”
4. MiOS Web Application
  1. On the MiOS web dashboard, you will be able to see the tile for vibration sensor and LED, which is controlled by using the vibration sensor according to rules we have set in the meshbot.
Meshbots
  1. On the right side of the screen under Automation, click on MeshBots.
  1. On meshbot screen, click on Create new MeshBot button present on the top right corner of the screen.
  2. After clicking on Create new MeshBot you will see this now under Automation MeshBot click on Local.
  1. On the next screen you will see that we can create a name of our choosing, in this case we write it as MQ3.
  1. Set these things in TRIGGER section:
  • Set Node Type to Device.
  • Set the Node to Vibration Sensor..
  • Set the Capability to Motion.
  • Set the value to True.
  1. Set these values in the TRUE part of the ACTION section.
  • Set Controllable Type to Device.
  • Set the Controllable to LED.
  • Set the Capability to switch.
  • Set the Value to true.
  • Switch action immediately
  1. Set these values in the False part of the ACTION section.
  • Set the Value to false.
  • Switch action immediately to Delay.
  • Set Delay to 5 seconds.
  1. Here you can see your saved MeshBot. Now click on Dashboard.
  1. After opening the MiOS web dashboard, you will be able to see the tile of your connected device. Currently, the tiles are off, which indicates that there is no vibration being detected that is why the LED tile is also shown as OFF.
  1. Now, we can see that when some vibration is detected, the LED turns ON but it will turn on for 5 secs and then turn off when no motion is detected because of the rules we have set in meshbot.
5. MiOS App
Google PlayApple App Store
  1. After successfully logging in, you will be able to see the number of controllers connected such as a lamp, fan, or any other device in the MiOS app. Tap on any controller of your desired ID.
  1. After opening the MiOS mobile app dashboard, you will be able to see the tile of your connected device. Here, as you can see, the sensor tile is displaying a message as “No Motion” when vibrations are not detected by the sensor so the LED is also OFF.
  1. Similarly, when it detects the vibration, “Motion” appears on the tile and our LED turns ON according to meshbot rules.
Buy Components
