Touch Switch with LED Example
The following example showcases how we can interface a touch sensor and LED with the EzloPi device and use it as a touch switch.
This setup allows you to use a touch sensor to control the operational state of the LED, providing visible feedback in response to a touch event. We can expand upon this foundation to create more complex and interactive applications with our EzloPi device.
Welcome to the project demonstration video section. The following video showcases the key aspects of Touch Switch with LED Example, providing a visual walkthrough of its implementation.
  • TTP223B Touch Sensor.
  • LED with a current limiting resistor of 82 Ohms value.
From ESP32(30 pins) to TTP223B Touch Sensor:
  • Connect 3V3 from the ESP32 to the VCC of the sensor.
  • Connect GND from the ESP32 to the GND pin on the sensor.
  • Connect D4 from the ESP32 to the SIG Pin on the sensor.
From ESP32(30 pins) to the LED:
  • Connect the D5 pin from the ESP32 to the LED anode (long leg) through a current limiting resistor of 82 Ohms.
  • Connect the GND to the cathode (short leg) of the LED.
The wiring diagram of esp32 30pin is represented as follows:
From ESP32(38 pins) to TTP223B Touch Sensor:
  • Connect 5V from the ESP32 to the VCC of the sensor.
  • Connect the IO4 from the ESP32 to the SIG Pin on the sensor.
From ESP32(38 pins) to the LED:
4. Interfacing the Touch Sensor module using EzloPi Web Flasher
  1. Now click on Connect Device and a pop-up window will appear
Click Connect.
  1. A Digital Output window will open for inputting the following parameters:
  • Set a device name of your choosing. In our case, we set it to Touch Switch.
  • Set Device subtype to LED.
  • Set OUT GPIO to 4.
  • Set Resistor to PULL UP.
  • Set the default value to LOW.
  • Check the Button Enable box.
  • Set INP GPIO to 5.
  • Set Resistor to PULL DOWN.
  • Now Click the Apply button.
5. MiOS App
Google PlayApple App Store
MiOS App
MiOS
  1. After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device. The touch sensor module works as a switch, the state of the LED is controlled by touching the sensor module.
  2. When a touch is detected by the sensor, the LED will turn ‘ON’ and remain ‘ON’ until another touch input is not detected by the sensor.
  1. Similarly, when another touch is detected by the sensor, the LED will turn ‘OFF’ and remain ‘OFF’ until another touch is not detected as shown above.
6. MiOS Web Application
  1. After opening the web dashboard, you will be able to see the tile of your connected device. The state of the LED is controlled by touching the sensor module.
  2. When a touch is detected by the sensor, the LED will turn ‘ON’ as can be seen above on the web dashboard and will remain ‘ON’ until another touch input is not detected by the sensor.
Buy Components
