Touch Sensor Digital Module With Buzzer
Touch Sensor Digital module with Buzzer
Turn Your Touch into Sound with EzloPi!
Top Projects
The following example showcases how we can interface a touch sensor and buzzer with the EzloPi device and use it as a touch switch.
This setup allows you to use a touch sensor to trigger the buzzer, providing audible feedback in response to a touch event. We can expand upon this foundation to create more complex and interactive applications with our EzloPi device.
Welcome to the project demonstration video section. The following video showcases the key aspects of the Touch Sensor Digital module with Buzzer, providing a visual walkthrough of its implementation.
  • TTP223B Capacitive Touch Sensor module.
  • Buzzer.
Touch sensor Digital Module With Buzzer BreadBoard
The following connections are made to complete the entire circuit setup.
From ESP32 (30 pins) to Touch Sensor Module:
  • Connect 3V3 from the ESP32 to the VCC of the module.
  • Connect the GND from the ESP32 to the GND pin on the module.
  • Connect the D4 pin from the ESP32 to the SIG Pin on the Touch Sensor module.
From ESP32 to the Buzzer:
  • Connect the D5 pin from the ESP32 to the positive terminal of the Buzzer.
  • Connect the GND to the negative terminal of the Buzzer.
The wiring diagram of ESP32 38 pin is also represented below:
From ESP32 (38 pins) to the Touch Sensor Module:
  • Connect GND from the ESP32 to the GND pin on the module.
  • Connect the GPIO4 pin from the ESP32 to the SIG Pin on the Touch Sensor module.
  • Connect the GPIO5 pin from the ESP32 to the Buzzer positive terminal.
  • Connect the GND to the Buzzer negative terminal.
4. Interfacing the Touch Sensor Digital module using EzloPi Web Flasher
1. Set up your device/hardware by visiting ezlogic.mios.com
  1. Log in using the credentials that you just set earlier while signing up.
Device Status
  1. Now click on Connect Device and a pop-up window will appear
PCI Serial port
  1. Now, select the COM Port to which your ESP32 device is connected. In our case, the COM3 port is used.
Click Connect.
Meta Data
  2. In the Device Configuration, tab click on Digital Output.
  1. A Digital Output window will open for inputting the following parameters:
  • Set a device name of your choosing. In our case, we set it to Buzzer with a Touch sensor.
  • Set the Device subtype to LED.
  • Set OUT GPIO to 5.
  • Set the Resistor to PULL UP.
  • Set the default value to LOW.
  • Check the Button Enable box.
  • Set INP GPIO to 4.
  • Set the Resistor to PULL DOWN.
  • Now click the Apply button.
  • After clicking the apply button, you can see a table of your settings in the device configuration tab.
  1. A window will appear on the bottom left side of the screen displaying “Please press the BOOT button while flashing begins.”
Ready to Flash
Device Flashed Successfully
5. MiOS App
Google PlayApple App Store
MiOS App
MiOS
Select a location
Bulb On
  1. After opening the dashboard, you will be able to see the tile of your connected device. The touch sensor module works as a touch switch, the state of the buzzer is controlled by touching the sensor module.
  2. When a touch is detected by the sensor, the Buzzer will turn ‘ON’ and remain ‘ON’ until another touch input is not detected by the sensor.
Bulb OFF
  1. Similarly, when another touch is detected by the sensor the Buzzer will turn ‘OFF’ and remain ‘OFF’ until another touch is not detected.
6. MiOS Web Application
Login to MiOS App
  1. After opening the web dashboard, you will be able to see the tile of your connected device. The state of the buzzer is controlled by touching the sensor module.
  2. When a touch is detected by the sensor, the Buzzer will turn ‘ON’ as can be seen above on the web dashboard and will remain ‘ON’ until another touch input is not detected by the sensor.
  1. Similarly, when another touch is detected by the sensor, the Buzzer will turn ‘OFF’ and remain ‘OFF’ until another touch is not detected as shown above.
Buy Components
