Harness the power of EzloPi!
Tilt detection using KY-20 tilt switch module
The following project aims to interface the KY-20 tilt switch module with the EzloPi device to detect orientation changes. The KY-20 module is a simple tilt sensor which reacts to tilt movements. The EzloPi device reads the digital signal from the KY-20 module and executes predefined actions which the user has set based on the tilt status. This project setup can be used for applications like motion detection, security systems, and automatic device shutdowns in case of abnormal tilts. The project involves wiring the components, configuring the EzloPi device to interpret the tilt sensor's output, handle the sensor’s data and trigger appropriate responses.
Welcome to the project demonstration video section. The following video showcases the key aspects of Tilt detection using KY-20 tilt switch module, providing a visual walkthrough of its implementation.
- KY-020 Tilt switch module.
From ESP32 to KY-020:
| ESP32 | KY-020 |
| VCC | Vin |
| GND | GND |
| D5 | S (Signal) |
4. Interfacing the Tilt Switch Module using the EzloPi Web Flasher
Click Connect
- The Digital Input window will open for inputting the following parameters:
- Set a Device name of your choosing. In our case, we set it to the Tilt Switch.
- Set Device Subtype to Digital In Switch / Button / Key.
- Set Resistor to PULL DOWN.
- Now, Click the Apply button.
5. MiOS App
- After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device.
- As you can see in the MiOS mobile dashboard, we can see the tilt switch tile. When the KY-020 module does not get tilted, the tile will display the "off” message as shown in the above image.
- Similarly, when the KY-020 gets a tilt signal, the tile will display the “On” message as depicted in the above image.
6. MiOS Web Dashboard
- As you can see in the MiOS web dashboard, we can see the tilt switch tile. When the KY-020 module does not get tilted, the tile will display the "off” message as shown in the above image.
MeshBots:
