Control Your Fan for Smart Temperature Control!
Temperature Control using Fan and DHT11 sensor
In this EzloPi project, we will be creating a smart temperature control system using the EzloPi device. The goal is to provide a convenient fan control with the MiOS application while harnessing the limitless capabilities of the EzloPi platform.
By utilizing the EzloPi device, we can integrate this smart temperature control system into our home automation setup. In this project, we have added the DHT11 temperature and humidity sensor to monitor the temperature control using a fan of any room or office. The fan can be switched ON/OFF using the MiOS applications remotely.
Welcome to the project demonstration video section. The following video showcases the key aspects of Temperature Control using Fan and DHT11 sensor, providing a visual walkthrough of its implementation.
- DHT11 Temperature & Humidity Sensor
- XL6009 DC to DC Boost Converter Module
- 12V DC fan
From ESP32 (30 pins):
- Connect the GND from the ESP32 to the GND pin of the DC-DC module.
- Connect the Vin pin from the ESP32 to the Common pin of the relay module.
- Connect the Vin pin from the ESP32 to the (+) positive terminal of the relay module.
- Connect the GND pin from the ESP32 to the (-) negative terminal of the relay module.
- Connect the D5 pin from the ESP32 to the S (Signal) pin of the relay module.
- Connect the D4 pin from the ESP32 to the OUT pin of the DHT11 sensor.
- Connect the 3.3V pin from the ESP32 to the (+) pin of the DHT11 sensor.
- Connect the GND pin from the ESP32 to the (-) pin of the DHT11 sensor.
From the Relay Module:
- Connect the NO pin from the relay module to the +ve pin on the DC-DC module.
From the DC-DC Boost Converter:
- Connect the OUT+ of the DC to DC module to +ve terminal of the DC fan.
- Connect the OUT- of the DC to DC module to the -ve terminal of the DC fan.
4. Interfacing the Temperature Control using Fan using EzloPi Web Flasher
Click Connect.
- If you are new to this and it’s your first time configuring, select Create new Device ID. Enter Wifi SSID and Wifi Password.
Interfacing the Relay module and fan with the EzloPi Web Flasher:
- Set a device name of your choosing. In our case, we set it to Fan with Touch.
- Set Device Subtype to Relay,
- Set the OUT GPIO to 5.
- Set the Resistor to PULL UP or PULL DOWN.
- Now Click the Apply button.
Interfacing the DHT11 sensor with the EzloPi Web Flasher:
- In the Device Configuration, tab click on One Wire.
- Set a device name of your choosing. In our case, we set it to Temperature & Humidity.
- Set the GPIO to 4.
- Set Device Subtype to DHT11 Temperature & Humidity Sensor.
- After some time, a popup will appear saying Device Flashed Successfully! ! This means that your device has been set up successfully.
5. MiOS App
- On the MiOS mobile dashboard, the tiles are displayed for our temperature control using a fan project. The DHT11 tile is displaying the current temperature of the room. If the temperature exceeds a certain limit, we can turn on the fan in order to reduce the temperature.
- As shown above, we have turned ON the fan. Hence, it can be seen that the temperature has decreased.
6. MiOS Web Application
- On the MiOS web dashboard, the tiles are displayed for our temperature control using a fan project. The DHT11 tile is displaying the current temperature of the room. If the temperature exceeds a certain limit, we can turn on the fan in order to reduce the temperature.
