Solar charged battery powered motion sensing using mini PIR sensor
Before moving into this example, it is very important to know about the device registration, provisioning and converting the ESP32 device into an EzloPi device along with knowledge of config.ezlopi.com Web Flasher, MiOS Mobile Application for Android/iOS and the MiOS Web Application.
This project aims to integrate the HC-SR505 mini PIR sensor, which is powered using a solar charged battery, and interfaced with the EzloPi device for standalone motion sensing. By leveraging the EzloPi's capabilities, such as its GPIO pins and compatibility with various sensors, the HC-SR505 will provide accurate detection of motion in its vicinity. The solar charging feature ensures continuous operation without relying solely on electricity, enhancing sustainability.
Through the EzloPi's MiOS interface, users can customize sensitivity settings, trigger actions upon motion detection, and receive notifications via connected devices or emails. This integration offers a cost-effective and a highly energy-efficient solution for monitoring and securing indoor and outdoor spaces.
Welcome to the project demonstration video section. The following video showcases the key aspects of Solar charged battery powered motion sensing using mini PIR sensor, providing a visual walkthrough of its implementation.
- HC-SR505 mini PIR sensor.
- Solar Panel ZW110X69.
- Solar panel Controller HW-150.
- 18650 battery.
From ESP32 to HC-SR505 mini PIR Sensor:
| ESP32 | HC-SR505 |
| 3V3 | VCC |
| GND | GND |
| D18 | SIG |
From Solar panel to Solar controller:
| Solar Panel | Solar Controller |
| Signal + | S+ |
| Signal - | S- |
From 18650 Battery to Solar controller:
| 18650 Battery | Solar Controller |
| +ve terminal | B+ |
| -ve terminal | B- |
From ESP32 to Solar controller:
| ESP32 | Solar Controller |
| Vin | L+ |
| GND | L- |
4. Interfacing the PIR motion sensor (HC-SR505) using the EzloPi Web Flasher
Click Connect.
- If you are new to this and it's your first time configuring, select Create new Device ID. Click on the Configure Wifi button. Enter Wifi SSID and Wifi Password.
- Set a device name of your choosing. In our case, we set it to Mini PIR motion Sensor.
- Set OUT GPIO to 4.
- Set Device subtype to PIR Sensor.
- Now Click the Apply button.
5. MiOS App
- Here, as you can see in the MiOS mobile app above, we can see the motion sensor tile. The above figure indicates that motion is being detected by the sensor.
6. MiOS Web Dashboard
- Here, as you can see in the MiOS web dashboard above, we can see the motion sensor tile. The above figure indicates that motion is being detected by the sensor.
- When no motion is detected by the sensor, the MiOS web dashboard tile will show the status “No motion” as above.
