This project aims to develop a robust and eco-friendly door monitoring system utilizing solar panel and battery power, coupled with the integration of the MC-38 magnetic door switch with the EzloPi device. This innovative system offers reliable security monitoring for various environments, including homes, offices, and commercial buildings. We have incorporated a solar panel to harness solar energy and charge the system's battery. A rechargeable battery unit will store the solar energy generated by the solar panel. This battery serves as a backup power source, ensuring uninterrupted functionality, even during periods of low sunlight or power outages. This sustainable power source ensures continuous operation and reduces energy consumption and lowers overall operational costs.
Welcome to the project demonstration video section. The following video showcases the key aspects of How to create a standalone solar and battery powered door monitoring system, providing a visual walkthrough of its implementation.
3. Circuit Diagram & Interface - HW-150 Solar
- ESP32 as an EzloPi smart device
- MC-38 Magnetic door switch
- Solar Panel ZW110X69
- Solar panel Controller HW-150
- 18650 battery
- LED
- Resistor 220 Ohms
The wiring diagram of ESP32 is represented as follows:
From ESP32 to the MC-38 Magnetic door switch:
From ESP32 to LED & Resistor:
From Solar panel to Solar controller:
From 18650 Battery to Solar controller:
From ESP32 to Solar controller:
4. Interfacing the MC-38 Magnetic door module using the EzloPi Web Flasher:
Click Connect.
- Set a device name of your choosing. In our case, we set it to the Door Sensor.
- Set the INPUT GPIO input pin to 4.
- Set device Subtype to Reed Switch.
- Set the Resistor Setting to PULL UP.
- Set the default value to LOW.
- Then click the Apply button.
- Again, In the Device Configuration, tab click on Digital Output.
- Set a device name of your choosing. In our case, we set it to LED.
- Set Device subtype to LED.
- Set OUT GPIO to 5.
- Set Resistor to PULL UP.
- Then Click Apply Button.
5. MiOS Web Application
- As seen in the MiOS web dashboard above, the door sensor tile is visible with the message “Closed” which means that the door sensor is detecting a magnetic field.
MeshBots:
- After clicking on Create new MeshBot you will see this now under Automation MeshBot click on Cloud.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Door with LED..
- Set these values in TRIGGER section:
Set Node Type to Device.
Set the Node to Sensor.
Set the Capability to Dw state.
Set the value to dw_is_closed.
- Click on the True part of the Add Action section..
- Set Node Type to Device.
- Set Controllable Type to LED.
- Set the Capability Type to switch.
- Set the Value to true.
- Set Action immediately.
- Now Click the Save button.
- Now, as seen in the MiOS web dashboard above, the door sensor tile is visible with the message “Open” which means that the door sensor is not detecting magnetic fields causing the LED to turn ON.
6. MiOS App
- After opening the dashboard, you will be able to see the tile of your connected device.
- As seen in the MiOS mobile dashboard, the door sensor tile is visible with the message “Closed” which means that the door sensor is detecting a magnetic field therefore the LED will remain OFF.
- Now, as seen in the MiOS mobile dashboard above, the door sensor tile is visible with the message “Open” which means that the door sensor is not detecting magnetic fields resulting in the LED to turn ON.
