Let your garden thrive with EzloPi smart soil monitoring!
Soil Monitoring using moisture sensor, DHT11 and LED
In this example, we have designed a soil monitoring system by utilizing the soil moisture sensor and DHT11, is a practical and efficient project aimed at helping gardeners, hobbyists and farmers to monitor and maintain optimal soil conditions for plant growth.
This project leverages the capabilities of the EzloPi device, which acts as the central control hub to control, collect and display data from the various sensors used. Users will also receive notifications or alerts through the EzloPi device when critical conditions or thresholds are met.
Welcome to the project demonstration video section. The following video showcases the key aspects of Soil Monitoring using moisture sensor, DHT11 and LED, providing a visual walkthrough of its implementation.
- DHT11 Digital Temperature and Humidity Sensor.
- FC-28 Soil Moisture Sensor Module.
- LED with a current-limiting resistor of 100 Ohm.
From ESP32 (30 pins) to the DHT11, Soil Moisture Sensor and LED:
- Connect the GND from the ESP32 to the GND (black) of DHT11, soil moisture sensor , LED cathode (small leg).
- Connect the 3V3 pin from the ESP32 to the Vin pin of DHT11 and soil moisture sensor.
- Connect the D2 pin from the ESP32 to the 100 ohm resistor and connect the resistor to the Anode (larger leg)
- of LED.
- Connect the D4 pin from the ESP32 to the DHT11’s Data pin.
- Connect the D5 pin from the ESP32 to the Signal pin of the soil moisture sensor.
4. Interfacing the Soil moisture sensor, DHT11 and LED using EzloPi Web Flasher
Click Connect
- If you are new to this and it’s your first time configuring, select Create new Device ID. Enter Wifi SSID and Wifi Password.
Interfacing the LED with EzloPi Web Flasher:
- A digital output window will open for inputting the following parameters:
- Set a device name of your choosing. In our case we set it to LED.
- Set Out GPIO to 2.
- Set Resistor to PULL UP.
- Set the default value to low
- Now Click the Apply button.
Interfacing the Soil Moisture Sensor with EzloPi Web Flasher:
- Set a device name of your choosing. In our case, we set it to Soil Moisture Sensor.
- Set device Subtype to Soil Moisture Sensor.
- Set the ADC input pin to 5.
- Set the Resolution to 10-bit.
- Now Click the Apply button. After clicking the apply button you can see a table of your setting in the device configuration tab.
Interfacing the DHT11 with EzloPi Web Flasher:
- In the Device Configuration, tab click on One Wire.
- A pop up window will open for inputting the following parameters:
- Set a device name of your choosing. In our case we set it to DHT11
- Set Out GPIO to 4.
- Select The Device Subtype as the sensor you are choosing. In our case, we set it to DHT11.
5. MiOS App
- After opening the MiOS mobile dashboard, we can see the tiles labeled for the “Soil Moisture Sensor”, “DHT11” and “LED”. We can monitor the soil moisture, temperature and humidity of the garden or plant anytime so that necessary actions can be taken when the soil moisture becomes very low. In our case, we are using LED as a demonstration which can be replaced with a water pump for a practical application.
- To explain better, assume that we are using a water pump in place of the LED. The water pump/LED can be switched ON/OFF remotely through the MiOS app interface. If soil moisture levels of a plant present in a room or an office space are low, the water pump/LED can be switched ON remotely.
- Here, the LED is OFF, indicating that the moisture levels of the soil is under the specified thresholds.
6. MiOS Web Application
- As shown above in the web dashboard, we can monitor the soil moisture, temperature and humidity of the garden or plant anytime so that necessary actions can be taken when the soil moisture becomes very low. In our case, we are using LED as a demonstration which can be replaced with a water pump for a practical application.
