FC-28 for Perfect Plant Hydration!
Soil moisture sensor with Servo motor
In this example, we have designed a soil monitoring system by utilizing the soil moisture sensor and servo motor. It is a convenient project aimed at helping gardeners, hobbyists and farmers to monitor and maintain optimal soil conditions for plant growth. We will be using the soil moisture sensor to measure the moisture levels in combination with a servo motor to open a valve for water inlet.
This project leverages the capabilities of the EzloPi device, to collect and display data from the various sensors used. Users will also receive notifications or alerts through the EzloPi device when critical conditions or thresholds are met.
- FC-28 Soil moisture sensor.
- MG996R Servo Motor with analog to digital interface module.
From ESP32 (30 pins) to the Soil Moisture Sensor Module:
- Connect the 3V3 pin from ESP32 to the VCC terminal of both the moisture sensor modules.
- Connect GND from ESP32 to the GND pins of both the moisture sensor modules.
- Connect the D33 from the ESP to the signal (A0) pin of one soil moisture sensor and D32 of ESP32 to the second soil moisture sensor.
From ESP32 (30 pins) to the Servo motor:
- Connect the GND from the ESP32 to the GND (black) pin of the MG996R Servo.
- Connect the Vin pin from the ESP32 to the 5V pin (Red) of MG996R Servo
- Connect the D5 pin from the ESP32 to the Yellow pin on the MG996R Servo.
3. Interfacing the Soil moisture sensor with servo motor using EzloPi Web Flasher
Click Connect.
Interfacing the Soil moisture sensor with EzloPi Web Flasher:
- Set a device name of your choosing. In our case we set it to Soil Moisture Sensor.
- Set device Subtype to Soil Moisture Sensor.
- Set the ADC input pin to 33.
- Set the Resolution to 10-bit.
- Now Click the Apply button.
Interfacing the second Soil moisture sensor with EzloPi Web Flasher:
- In the Device Configuration, tab click on PWM.
- A PWM window will open for inputting the following parameters:
- Set a Device Name of your choosing. In our case, we set it to servo.
- Set Device Subtype to MG996R Servo.
- Set the ADC PWM_GPIO to 5.
- Set the Resolution to 8-bit.
4. MiOS App
- After some time, a popup will appear saying Device Flashed Successfully! ! This means that your device has been set up successfully.
4. MiOS App
- After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device. As in this case, we can see tiles labeled as “Soil Moisture Sensor” and “Servo".
- Similarly, we can also turn off the servo motor by also using the MiOS web app.
5. MiOS Web Application
- After opening the MiOS web dashboard, you will be able to see the tile of your connected device. As in this case, we can see tiles labeled as “Soil Moisture Sensor” and “Servo".
- We are monitoring the soil moisture. As the moisture content in the soil decreases, we can manually switch on the servo motor just like a water pump or like a water valve to provide the required amount of water to the soil.
