Keep plants healthy with EzloPi!
Soil moisture measurement using HW-330 capacitive soil moisture sensor
The project aims to integrate the HW-330 capacitive soil moisture sensor with the EzloPi device for precise soil moisture measurement. The HW-330 sensor employs capacitive sensing technology to accurately determine soil moisture levels, offering reliable data for agricultural and gardening applications. By interfacing this sensor with EzloPi, users can monitor soil moisture remotely, enabling timely irrigation and preventing over or under-watering.
Additionally, capacitive soil moisture sensors are less prone to corrosion and interference from salts compared to traditional resistive sensors, enhancing their longevity and accuracy. This integration facilitates efficient water management and promotes healthier plant growth, ultimately optimizing agricultural productivity and resource utilization.
Welcome to the project demonstration video section. The following video showcases the key aspects of Soil moisture measurement using HW-330 capacitive soil moisture sensor, providing a visual walkthrough of its implementation.
- HW-330 Capacitive soil moisture sensor.
From ESP32 to the Capacitive Soil moisture sensor:
| ESP32 | Capacitive Soil Moisture Sensor |
| 3V3 | VCC |
| GND | GND |
| D33 | A |
4. Interfacing the Capacitive Soil moisture sensor using the EzloPi Web Flasher:
Click Connect
- If you are new to this and it's your first time configuring, select Create new Device ID. Click on the Configure Wifi button. Enter Wifi SSID and Wifi Password.
- Set a device name of your choosing. In our case we set it to Capacitive Soil Moisture Sensor.
- Set the Device Subtype to Soil Moisture Sensor.
- Set the ADC input pin to 33.
- Now Click the Apply button.
5. MiOS App
- After opening the dashboard, you will be able to see the tile of your connected device.
- After opening the MiOS mobile app, we can see the moisture sensor tile which shows the amount of moisture in the soil for our plant.
6. MiOS Web Dashboard
- After opening the MiOS web dashboard, we can see the moisture sensor tile which shows the amount of moisture in the soil of our plant.
