Smart innovation with EzloPi
Smart weight measurement using load cell and 3D printed base
This project utilizes a load cell with the HX711 weight sensor module to accurately measure weights and display the results on the MiOS smart platform. The load cell is mounted on a custom 3D-printed base, ensuring a stable and reliable structure for consistent measurements. The HX711 module amplifies and converts the analog signals from the load cell into digital data, which is processed by the EzloPi device. This system can provide real-time weight readings, making it suitable for smart inventory management, automated weighing, or IoT-based applications.
- Load cell with HX711 weight sensor module.
From ESP32 to the HX711 module:
ESP32 | HX711 |
VIN | VCC |
GND | GND |
D12 | CK |
D13 | DO |
From HX711to the Load cell:
HX711 | Load Cell |
E+ | Red |
E- | Black |
A+ | Green |
A- | White |
4. Interfacing the Load cell with weight sensor module using the EzloPi Web Flasher:
Click Connect
- f you are new to this and it's your first time configuring, select Create new Device ID. Click on the Configure Wifi button. Enter Wifi SSID and Wifi Password.
- An Other window will be opened for inputting the following parameters:
- Set a Device name of your choosing. In our case, we set it to HX711.
- Set Device Subtype to HX711 LOADCELL.
- Tick mark the GPIO1 and GPIO2 boxes.
- Set the GPIO1 pin to 12.
- Set the GPIO1 pin to 13.
- Then Click Apply Button
5. MiOS App
- After opening the MIOS mobile app, you will be able to see the tile of your connected device. The HX711 load cell is used here with the 3D printed base which holds the load cell in an appropriate position to measure weight. We have measured a glass of water so the tile here is showing the weight of the glass of water in the Kg unit.
6. MiOS Web Dashboard
- After opening the MIOS web dashboard, you will be able to see the tile of your connected device. The HX711 load cell is used here with the 3D printed base which holds the load cell in an appropriate position to measure weight. We have measured a glass of water so the tile here is showing the weight of the glass of water in the Kg unit.
