Monitor your surroundings with EzloPi!
Smart weather station with EzloPi
The smart weather station project using the EzloPi device will monitor environmental conditions such as temperature, humidity, and atmospheric pressure and rain. The project will collect real-time sensor data and display it on the MiOS smart platform. The project is designed to work efficiently in various environments, potentially integrating features like wireless data transmission and local storage for weather history. The project aims to create an easily deployable and scalable weather monitoring solution utilizing the EzloPi smart IoT platform.
Welcome to the project demonstration video section. The following video showcases the key aspects of Smart greenhouse garden using soil moisture sensor, LDR and MQ135 sensor, providing a visual walkthrough of its implementation.
- 5V BME280 Barometric pressure & humidity sensor.
- LM393 comparator IC module.
- FC-37 rain sensor module.
- LM393 based 4-pin photoresistor sensor module (LDR).
From ESP32 to the BME280:
| ESP32 | BME80 |
| VIN | VIN |
| GND | GND |
| D21 | SCL |
| D22 | SDA |
From ESP32 to the LM393 comparator module:
| ESP32 | LM393 Comparator Module |
| VCC | VCC |
| GND | GND |
| D33 | A0 |
From the LM393 module to the Rain sensor:
| LM393 Comparator Module | Rain Sensor Module |
| Pin 1 | POS |
| Pin 2 | NEG |
From ESP32 to LDR Module:
| ESP32 | LDR Module |
| 3V3 | VCC |
| GND | GND |
| D25 | D0 |
4. Interfacing the Rain Sensor, LDR and pressure sensor with the EzloPi Web Flasher:
Click Connect
- A I2C Input window will open for inputting the following parameters:
- Set a Device name of your choosing. In our case, we set it to BME280.
- Set Device Subtype to BME 280 Sensor.
- Set the Slave Address to 118.
- Set the SDA pin to 21.
- Set the SCL pin to 22.
- Tick the “Enable Pullup” for both the SDA and SCL.
- Then Click Apply Button.
- Again, In the Device Configuration, tab click on Analog Input.
- Set a Device name of your choosing. In our case, we set it to the Rain Sensor.
- Set Device Subtype to Water Leak Sensor.
- Set the ADC input pin to 33.
- Set the Resolution to 10-bit.
- Again, In the Device Configuration, tab click on Digital Input.
- Set a Device name of your choosing. In our case, we set it to LDR.
- Set INPUT GPIO to 25.
- Set Device Subtype to LDR Sensor (Digital).
- Set Resistor to PULL UP.
- Set Default value to LOW.
5. MiOS App
- After opening the MiOS web dashboard, you will be able to see the tiles of your connected devices. As we can see above, the BMP280 sensor module tile is showing the current humidity and temperature values, while the rain sensor shows the No rain or No leak message for now and the LDR sensor tile is ON because there is light present in the environment.
- Now, it is showing that it is raining so the humidity value has increased. The Rain sensor is detecting rain and the LDR is showing an OFF message because of low light in the environment.
6. MiOS Web Dashboard
- After opening the MiOS mobile dashboard, you will be able to see the tiles of your connected devices. As we can see above, the BMP280 sensor module tile is showing the current humidity and temperature values, while the rain sensor shows the No rain or No leak message for now and the LDR sensor tile is ON because there is light present in the environment.
