Smart automation with EzloPi!
Smart water level monitoring with email notification using P45 float switch
This project aims to interface a P45 float switch with the EzloPi device for efficient water level detection. The P45 float switch is a simple yet effective liquid level sensor, which is integrated with the EzloPi device to enable real-time monitoring of water levels in various applications for users. This smart monitoring is done by utilizing the MiOS smart platform for allowing the users to monitor and notify them about various water level conditions. Subsequently, the user is notified via email when the water levels increase above a certain threshold.
The float switch, when interfaced with the EzloPi device, can have many applications for smart automation purposes such as it can accurately detect water levels in tanks for management of water resources. It can also monitor water levels for triggering the operation of motors such as pumps or valves, for optimal water usage and preventing overflow or shortages.
Welcome to the project demonstration video section. The following video showcases the key aspects of Smart water level monitoring with email notification using P45 float switch, providing a visual walkthrough of its implementation.
- P45 float switch.
From ESP32 to the Float Switch:
| ESP32 | Float Switch |
| GND | 1st terminal |
| D5 | 2nd terminal |
4. Interfacing the float switch using the EzloPi Web Flasher
Click Connect
- Set Device name to Button 1.
- Set OUT GPIO to 15.
- Set Device subtype to Digital In Switch / Button / Key.
- Set the default value to LOW.
- Then Click Apply Button.
5. MiOS Web Dashboard
- As seen in the MiOS web dashboard above, the float switch tile is visible. It will show messages like “water_level_ok” or “water_level_above_high_threshold” when operational. The user will get notified via email when the water level reaches a set threshold.
MeshBots:
- After clicking on Create new MeshBot you will see new options, now under Notification MeshBot click on Create.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test001.
- Set these values in TRIGGER section:
- Set Node Type to Device.
- Set the Node to Float Switch.
- Set the Capability to Water level alarm.
- Set the value to water_level_above_high_threshold.
- Set Controllable Type to Notification.
- Set the User to Your user account.
- Set the Channels to email, push.
- Set the Subject to Water Level Alert.
- Write the suitable Message body that you want to receive in your email. As you can see, we write, Water is above threshold level.
- As seen in the MiOS web dashboard above, the float switch sensor tile is visible with the message “Water_level_ok” which means that the float switch is not triggered or not detecting water.
- Now, the float switch sensor tile is visible with the message “Water_level_above_high_threshold” which means that the float switch is triggered or detecting water and an automated email is sent to the user as seen below.
- As we can see we have received email through Meshbot when a water level is above threshold level..
6. MiOS App
- After opening the dashboard, you will be able to see the tile of your connected device.
- As seen in the MiOS mobile app above, the float switch sensor tile is visible with the message “Water_level_ok” which means that the float switch is not triggered or not detecting water.
