Smart Parking Assistance with EzloPi
This project involves interfacing the JSN-SR04T ultrasonic sensor with the EzloPi device to provide real-time parking guidance. The JSN-SR04T sensor, known for its waterproof design and long-range detection, measures the distance between the vehicle and obstacles or walls. By integrating it with the EzloPi platform, the system will alert users of nearby objects, helping to avoid collisions while parking. This solution can be expanded with additional features like LED indicators for enhanced user experience.
Welcome to the project demonstration video section. The following video showcases the key aspects of Smart Parking Assistance with EzloPi, providing a visual walkthrough of its implementation.
  • JSN-SR04T Ultrasonic Sensor with analog to digital interface module
  • LED with 120 Ohm Resisor
From ESP32 to the JSN SR04T:
ESP32JSN SR04T
VINVIN
GNDGND
GPIO5ECHO PIN
GPIO12TRIG PIN
From ESP32 to the LED:
ESP32LED
GPIO4Long Leg with 120 Ohm resistor
GNDSmall leg
4. Interfacing the Ultrasonic sensor with the EzloPi Web Flasher:
Click Connect
  2. In the Device Configuration, tab click on I2C.
  1. A I2C Input window will open for inputting the following parameters:
  • Set a device name of your choosing. In our case, we set it to JSNSR04T.
  • Set Device Subtype to JSN SR04T
  • Set the GPIO1 to 5.
  • Set the GPIO2 to 12.
  • Then Click Apply Button.
  1. In the Device Configuration, tab click on Digital Output.
  1. A Digital Output window will open for inputting the following parameters:
  • Set a Device name of your choosing. In our case, we set it to the LED.
  • Set Device Subtype to LED.
  • Set the OUT GPIO to 4.
  • Set the Resistor to PULL UP.
5. MiOS Web Dashboard
  1. Here, on the MiOS web dashboard, you will be able to see the tiles of connected devices. In our case we have a JSN-SR04T sensor and LED tiles. The LED tile will indicate the status of the LED depending on the distance being detected by the JSN-SR04T sensor.
MeshBots:
  1. On the left side of the screen under Automation, click on MeshBots.
  2. On meshbot screen, click on Create new MeshBot button present on the top right corner of the screen.
  3. After clicking on Create new MeshBot, you will see this now under Automation MeshBot click on Local.
  1. On the next screen you will see that we can create a name of our choosing, in this case we write it as Test005.
  1. Set these things in TRIGGER section:
  • Set Node Type to Device.
  • Set the Node to JSNSR04T.
  • Set the Category to power.
  • Set the variables to status.
  • Set the Comparator to Equal (==).
  • Set the Value Type to value.
  • Set the value to 3m.
  1. Set these values in the TRUE part of the ACTION section.
  • Set Controllable Type to Device.
  • Set the Controllable to LED.
  • Set the Capability to switch.
  • Set the Value to true.
  • Set Action to immediately.
  1. Set these values in the FALSE part of the ACTION section.
  • Set the Value to false.
  • Now Click the Save button.
  1. Here you can see your saved MeshBot. Now click on Dashboard.
  1. Now in the MiOS web dashboard, we can see that when the distance reaches a certain value, then the LED turns ON because of the rules we have set in meshbot.
6. MiOS App
Google PlayApple App Store
  1. Here, as seen above on the MiOS mobile dashboard, we can see that when the distance remains in a pre-defined range, the LED remains OFF because of the rules we have set in meshbot.
  1. Now in the MiOS web dashboard, we can see that when the distance reaches a certain value defined by the user then the LED turns ON because of the rules we have set in meshbot.
Buy Components
