Go smart with EzloPi!
Smart lighting system for energy efficiency
The smart lighting system for energy efficiency leverages the LTR303ALS luminous intensity sensor and DHT22 temperature and humidity sensor, interfaced with the EzloPi device. This system dynamically adjusts lighting based on ambient light levels and environmental conditions, ensuring optimal illumination while minimizing energy consumption. The LTR303ALS monitors light intensity, enabling the system to dim or brighten lights as needed, while the DHT22 provides temperature and humidity data for integrated climate-responsive control. Designed for homes and offices, this smart lighting solution enhances user comfort, reduces electricity costs, and promotes sustainable energy practices.
- LTR303ALS Luminous Intensity Sensor.
- DHT22 Temperature and Humidity Sensor.
The wiring diagram of ESP32 30 pin is represented as below:
From ESP32 to the LTR303ALS:
ESP32 | LTR303ALS |
3V3 | VCC |
GND | GND |
D21 | SDA |
D22 | SCL |
From ESP32 to the DHT22:
ESP32 | DHT22 |
VIN | VCC |
GND | GND |
D15 | Data Signal |
4. Interfacing the LTR303ALS & DHT22 using the EzloPi Web Flasher
Click Connect
- An I2C window will be opened for inputting the following parameters:
- Set a Device name of your choosing. In our case, we set it to Luminosity Sensor.
- Set Device Subtype to LTR303ALS Luminosity Sensor.
- Set the Slave address to 41.
- Set the SDA pin to 21.
- Set the SCL pin to 22.
- Tick mark both boxes of Enable pullup.
- Then Click Apply Button.
- Again, In the Device Configuration, tab click on One Wire
- A One Wire window will be opened for inputting the following parameters:
- Set a Device name of your choosing. In our case, we set it to DHT22.
- Set the GPIO to 15.
- Set Device Subtype to DHT22 Temperature Humidity Sensor.
5. MiOS App
- After opening the MIOS mobile app, you will be able to see the tiles of your connected devices. The DHT22 shows temperature and humidity data whereas LTR303ALS shows light intensity. Here, we have a scenario that when the sun is out there is more light intensity shown by the luminosity sensor and also the temperature and humidity values are high.
- When this situation happens, we can power up our ACs or fans and turn ON our lights automatically with this smart system.
- Here, in the above picture, we can see that now there is a different scenario from the previous. Now there is less light detected by the luminosity sensor and temperature and humidity drop low so now we can set our ACs temperature or fans speed accordingly and turn ON our lightings automatically with the help of this smart system.
6. MiOS Web Dashboard
- After opening the MIOS web dashboard, you will be able to see the tiles of your connected devices. The DHT22 shows temperature and humidity data whereas LTR303ALS shows light intensity. Here, we have a scenario that when the sun is out there is more light intensity shown by the luminosity sensor and also the temperature and humidity values are high.
