Solution for every problem!
Smart irrigation monitoring system
The following project integrates the MB1013 sonar sensor module and FC-28 soil moisture sensor module with the EzloPi device to optimize water usage. The sonar sensor monitors water levels in the reservoir, while the soil moisture sensor determines the soil's hydration status. The EzloPi device processes these sensor inputs and activates a pump or valve for irrigation when necessary, ensuring efficient water management. This system promotes sustainable agricultural practices by preventing overwatering and conserving resources.
- MB1013 sonar sensor module.
- FC-28 soil moisture sensor module with LM393 comparator IC module.
From ESP32 to the MB1013 sonar sensor:
| ESP32 | MB1013 |
| 3V3 | VCC |
| GND | GND |
| D16 (RX) | Tx |
| D17 (TX) | Rx |
From ESP32 to the LM393 comparator module:
| ESP32 | LM393 comparator module |
| 3V3 | VCC |
| GND | GND |
| D3 | A0 |
From the LM393 module to the FC-28 Soil moisture sensor:
| LM393 Comparator Module | FC-28 |
| + ve pin | POS |
| - ve pin | NEG |
4. Interfacing the MB1013 sonar sensor & FC-28 soil moisture sensor using the EzloPi Web Flasher
Click Connect
- In the Device Configuration, tab click on UART.
- A UART window will be opened for inputting the following parameters:
- Set a Device name of your choosing. In our case, we set it to Sonar Sensor.
- Set Device subtype to MB1013.
- Set GPIO RX to 16.
- Set GPIO TX to 17.
- Set Baud Rate to 9600.
- Then Click Apply Button.
- Again, In the Device Configuration, tab click on Analog Output
- An Analog Input window will be opened for inputting the following parameters:
- Set a Device name of your choosing. In our case, we set it to the Soil Moisture Sensor.
- Set Device Subtype to FC-28 Soil Moisture Sensor.
- Set the ADC input pin to 33.
- Set the Resolution to 10-bit.
5. MiOS Web Dashboard
- On the MiOS web dashboard, you will be able to see the tile of your connected device. We have an MB1013 and FC-28 soil moisture sensor shown here. They are used together to make an efficient irrigation system.
MeshBots:
- After clicking on Create new MeshBot, you will see this now under Notification MeshBot click on Create.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test014.
- Set Node Type to Device.
- Set the Node to Soil Moisture Sensor.
- Set the Capability to parent_abstract.
- Set the Variables to uuid.
- Set the Comparator to Greater (>).
- Set the Value to 25.
- Set Controllable Type to Notification.
- Set the User to Your user account .
- Set the Channels to email,push.
- Set the Subject to Soil Moisture Update.
- Write the suitable Message body that you want to receive in your email. As you can see, we write, The Plant is being watered.
- Now as shown above, the soil moisture sensor is sensing a low value of moisture whereas the MB1013 distance sensor also gets a high value of distance value.
- Now as shown above, the soil moisture sensor now senses a high value of moisture that's why notification is issued to the user about the moisture of the plant. Also the MB1013 sensor also gets low distance value implying that someone is watering plants.
6. MiOS App
- After opening the mobile dashboard, you will be able to see the tile of your connected device. The soil moisture sensor is sensing a low value of moisture whereas the MB1013 distance sensor also gets a high value of distance value.
