Smart management and convenience!
Smart inventory management system
The smart inventory management system deploys a load cell with an HX711 weight sensor module and an LED, interfaced with the EzloPi device. This system monitors weight changes on inventory shelves to detect the addition or removal of items. When an item is placed or taken, the load cell registers the weight difference, enabling automatic inventory tracking. The LED serves as a status indicator for real-time updates. This setup ensures efficient stock monitoring, reducing manual errors and improving inventory control for businesses or storage solutions.
- Load cell with HX711 weight sensor module.
- LED with 120 Ohms Resistor.
From ESP32 to the HX711 module:
| ESP32 | HX711 |
| VIN | VCC |
| GND | GND |
| D12 | CK |
| D13 | DO |
From HX711to the Load cell:
| HX711 | Load Cell |
| E+ | Red |
| E- | Black |
| A+ | Green |
| A- | White |
From ESP32 to the LED & Resistor:
| ESP32 | LED | Resistor |
| D15 | - | Terminal 1 |
| - | Anode | Terminal 2 |
| GND | Cathode | - |
4. Interfacing the Load Cell & HX711 Module with EzloPi Web Flasher
Click Connect
- An Other window will be opened for inputting the following parameters:
- Set a Device name of your choosing. In our case, we set it to HX711.
- Set Device Subtype to HX711 LOADCELL.
- Tick mark the GPIO1 and GPIO2 boxes.
- Set the GPIO1 pin to 12.
- Then Click Apply Button.
- Again, In the Device Configuration, tab click on Digital Output
- A Digital Output window will be opened for inputting the following parameters:
- Set a Device name of your choosing. In our case, we set it to LED.
- Set Device Subtype to LED.
- Set the OUT GPIO to 15.
5. MiOS Web Dashboard
- On the MiOS web dashboard, you will see the tiles of your connected devices as shown above labeled as HX711 and LED. The LED will indicate the conditions according to the output of the load cell which we will set in the meshbot.
MeshBots:
- After clicking on Create new MeshBot, you will see this now under Automation MeshBot click on Cloud.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test015.
- Set Node Type to Device.
- Set the Node to HX711.
- Set the Capability to parent_abstract.
- Set the Variable to uuid.
- Set the Comparator to Greater (>).
- Set the Value to 4.55.
- Add another device by pressing the Add Trigger button.
- Set the Comparator to Less (<).
- Set the Value to 4.45.
- Select the OR condition for both branches from the top left corner.
- Set Controllable to LED.
- Set the Capability to power_command.
- Set the Value Type to set.
- Set the value to false.
- Now, on the MiOS web dashboard, we can see that when the load cell detects a weight which is more than 4.55kg as per the condition set in the meshbot, then the LED gets turned ON to indicate that some new inventory is added to the inventory shelf.
- Here, we can see that when the load cell gets less weight than 4.45kg which we have set in the meshbot then the LED gets turned ON to indicate that some inventory is taken out of the inventory shelf.
6. MiOS App
- On the MiOS mobile app dashboard, we can see that when the load cell detects a weight which is more than 4.55kg as per the condition set in the meshbot, then the LED gets turned ON to indicate that some new inventory is added to the inventory shelf.
