Be smart with EzloPi!
Smart interaction detection system
This project leverages the FC-51 proximity sensor module and a force sensitive resistor (FSR) interfaced with the EzloPi device to detect and respond to human interactions or object presence. The FC-51 sensor identifies proximity changes, while the FSR measures applied pressure or force. These inputs can be used to enable the system to trigger specific actions, such as activating LEDs, initiating notifications, or controlling connected devices. This system is ideal for applications like interactive kiosks, smart surfaces, or automated response systems.
- FC-51 Proximity sensor module.
- Force Sensitive Resistor with pull-down Resistor.
From ESP32 to the FC-51 Proximity sensor module:
| ESP32 | FC-51 |
| 3V3 | VCC |
| GND | GND |
| D15 | OUT |
From ESP32 to the Force Sensitive Resistor & Pull-down Resistor:
| ESP32 | Force Sensitive Resistor | Pull Down Resistor |
| VIN | Terminal 1 | - |
| D33 | Terminal 2 | Terminal 1 |
| GND | - | Terminal 2 |
4. Interfacing the Proximity Sensor & Force Sensitive Resistor using the EzloPi Web Flasher
Click Connect
- f you are new to this and it's your first time configuring, select Create new Device ID. Click on the Configure Wifi button. Enter Wifi SSID and Wifi Password.
- A Digital Input window will be opened for inputting the following parameters:
- Set a Device name of your choosing. In our case, we set it to Proximity Sensor.
- Set INPUT GPIO to 15.
- Set Device subtype to Proximity Sensor.
- Set Resistor to PULL DOWN.
- Then Click Apply Button.
- Again, In the Device Configuration, tab click on Analog Input
- An Analog Input window will be opened for inputting the following parameters:
- Set a Device name of your choosing. In our case we set it to Force Sensor.
- Set the Device Subtype to Force Sensitive Resistor.
- Set the ADC input pin to 33.
- Set the Resolution to 10-bit.
5. MiOS App
- After opening the MIOS mobile app, you will be able to see the tiles of your connected devices. Here, we have proximity sensor and force sensor which can be used to efficiently make smart interactive devices work. We can see in the picture that when the proximity sensor does not detect any object or body, the force sensor also shows a low value of force which implies that there is no interaction with our devices for now.
- In the above picture we can see that the proximity sensor gets some movement signal and the force sensor also senses a high value of force which depicts that some interaction is detected. From utilizing these two sensors we can efficiently make smart interactive devices.
6. MiOS Web Dashboard
- After opening the MIOS web dashboard, you will be able to see the tiles of your connected devices. Here, we have proximity sensor and force sensor which can be used to efficiently make smart interactive devices work. We can see in the picture that when the proximity sensor does not detect any object or body, the force sensor also shows a low value of force which implies that there is no interaction with our devices for now.
- Here, in the above picture we can see that the proximity sensor gets some movement signal and the force sensor also senses a high value of force which depicts that some interaction is detected. From utilizing these two sensors we can efficiently make smart interactive devices.
