Smart Home Lighting System with 8 channel Relay
This example shows how you can connect your home appliances to an EzloPi smart device and convert your boring home into a smart home. By using an 8 channel relay module, EzloPi smart device enables you to control the status of your appliances from anywhere in the world. You can monitor if an appliance is turned on or off at any given time and change its status on the fly.
Welcome to the project demonstration video section. The following video showcases the key aspects of Smart Home Lighting System with 8 channel Relay on EzloPi platform, providing a visual walkthrough of its implementation.
  • 8 channel 5v Relay module
The following connections are made in order to complete the entire circuit setup:
From ESP32 to the Relay Module:
  • Connect the D22 pin from the ESP32 to the 1st Channel of the relay module.
  • Connect the D21 pin from the ESP32 to the 2nd Channel of the relay module.
  • Connect the D19 pin from the ESP32 to the 3rd Channel of the relay module.
  • Connect the D18 pin from the ESP32 to the 4th Channel of the relay module.
  • Connect the D5 pin from the ESP32 to the 5th Channel of the relay module.
  • Connect the D4 pin from the ESP32 to the 6th Channel of the relay module.
  • Connect the D2 pin from the ESP32 to the 7th Channel of the relay module.
  • Connect the D15 pin from the ESP32 to the 8th Channel of the relay module.
  • Connect the GND to the GND of the relay module.
  • Connect the ‘VCC’ terminal to 3V3.
From Relay Module to 220VAC Bulb:
  • Connect the common pins(middle pin) of the relay module to the neutral of mains supply.
  • Connect Normally open terminals of relay modules with one of the terminal of each bulb.
    NormallyOpen1 <----------> Bulb1
    NO2 <----------> B2
    NO3 <----------> B3
    NO4 <----------> B4
    NO5 <----------> B5
    NO6 <----------> B6
    NO7 <----------> B7
    NO8 <----------> B8
  • Connect the second terminal of each bulb with the phase of mains supply.
3. Interfacing the 8 Channel Relay Module using EzloPi Web Flasher:
Click Connect.
  2. In the Device Configuration, tab click on Digital Output.
  • Set Device subtype to Relay of channel 1.
  • Set OUT GPIO to 22.
  • Set Resistor to PULL UP.
  • Set the default value to LOW.
  • Then Click Apply Button.
  1. Then click again on Digital Output :
  • Set Device subtype to Relay of channel 2.
  • Set OUT GPIO to 21.
  • Set Device subtype to Relay of channel 3.
  • Set OUT GPIO to 19.
  • Set Device subtype to Relay of channel 4.
  • Set OUT GPIO to 18.
  • Set Device subtype to Relay of channel 5.
  • Set OUT GPIO to 5.
  • Set Device subtype to Relay of channel 6.
  • Set OUT GPIO to 4.
  • Set Device subtype to Relay of channel 7.
  • Set OUT GPIO to 2.
  • Set Device subtype to Relay of channel 8.
  • Set OUT GPIO to 15.
4. MiOS App
Google PlayApple App Store
  1. After opening the web dashboard, you will be able to see the tile of your connected device. The state of the 8 Channel relay module is controlled by the just touching screen button as shown on the web.
  2. When the button glows blue after touching, the relay module will turn ‘ON’ the bulb.
  1. Similarly, When the button color turns white after touching, the relay module will turn “OFF” the bulb.
5. MiOS Web Application
Buy Components
