Smart projects to make life easier
Single-axis level meter using accelerometer and LEDs
This project utilizes the capabilities of the EzloPi device for interfacing a GY-61 3-axis accelerometer to enable precise angle monitoring for leveling applications. By focusing on one axis, the device calculates tilt and displays its status via three LEDs. The GY-61 accelerometer accurately detects slight angle deviations, allowing for quick visual feedback. This system is ideal for applications requiring clear, real-time level indication, such as construction leveling or equipment calibration.
Welcome to the project demonstration video section. The following video showcases the key aspects of Single-axis level meter using accelerometer and LEDs, providing a visual walkthrough of its implementation.
- GY-61 3-axis accelerometer.
- 3 LEDs with 120 Ohm resistors.
From ESP32 to the GY-61:
| ESP32 | GY-61 |
| VIN | VIN |
| GND | GND |
| D25 | Zout |
| D33 | Yout |
| D32 | Zout |
From ESP32 to the LED1 & Resistor1:
| ESP32 | LED2 | Resistor3 |
| D5 | - | Terminal 1 |
| GND | Cathode | - |
| - | Anode | Terminal 2 |
4. Interfacing the GY-61 3-axis accelerometer & 3 LEDs with the EzloPi Web Flasher:
Click Connect
- A Other Input window will open for inputting the following parameters:
- Set a Device name of your choosing. In our case, we set it to GY-61 3-Axis Accelerometer.
- Set Device Subtype to GY61 3-Axis Accelerometer.
- Tick mark the box of GPIO1 and Set the GPIO1 to 25.
- Tick mark the box of GPIO2 and Set the GPIO2 to 32.
- Tick mark the box of GPIO3 and Set the GPIO3 to 33.
- Then Click Apply Button.
- Set a Device name of your choosing. In our case, we set it to the LED 1.
- Set Device Subtype to LED.
- Set the OUT GPIO to 15.
- In the Device Configuration, tab click on Digital Output
- Set a Device name of your choosing. In our case, we set it to the LED 2.
- Set the OUT GPIO to 4.
- Set a Device name of your choosing. In our case, we set it to the LED 3.
- Set the OUT GPIO to 5.
5. MiOS Web Dashboard
- Here, on the MiOS web dashboard, you will be able to see the tiles of connected devices. In our case, we have two visible tiles for the GY-61 sensor which are of Y-axis and Z-axis respectively whereas there are tiles for LED also. The LED tile will indicate the stability of the Z-axis.
MeshBots:
- After clicking on Create new MeshBot, you will see this now under Automation MeshBot click on Cloud.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test011.
- Set Node Type to Device.
- Set the Node to GY-61 3-Axis Accelerometer.
- Set the Capability to parent_abstract.
- Set the variables to uuid.
- Set the Comparator to Greater (>).
- Set the value to 0.
- Set the Controllable to LED 1.
- Set the Capability to power_command.
- Set the Value Type to set.
- Set the value to true.
- Again Click on Create new Meshbot and under Automation MeshBot click on Cloud.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test012.
- Set the Comparator to Equal (==).
- Set the Controllable to LED 2.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test013.
- Set the Comparator to Less (<).
- Set the Controllable to LED 3.
- Now Click the Save button.
- Now in the MiOS web dashboard, we can see the values of Y-axis and Z-axis and also the tiles of 3 LEDs. We want to indicate only the Z-axis level through the LEDs. Here when the Z-axis value goes above 0 then LED 1 gets turned ON due to our meshbot settings.
- Now in the above picture, we can see that the value of the Z-axis is stable at 0 then the LED 2 turns ON because of our setting of meshbot.
- Here in this picture, we can see that the value of the Z-axis goes below 0 then the LED 3 turns ON because of our setting of meshbot.
6. MiOS App
- Here, as seen above on the MiOS mobile dashboard, we can see the values of Y-axis and Z-axis and also the tiles of 3 LEDs. We want to indicate only the Z-axis level through the LEDs. So here when the Z-axis value goes above 0 then LED 1 gets turned ON due to our meshbot settings.
