Discover smart motion with EzloPi!
Sense the change in orientation using tilt switch and LED
The following project aims to interface the KY-20 tilt switch module with the EzloPi device to detect orientation changes. The KY-20 module is a simple tilt sensor which reacts to tilt movements. The EzloPi device reads the digital signal from the KY-20 module and executes predefined actions which the user has set based on the tilt status. This project setup can be used for applications like motion detection, angle or tilt detection in robotic arms, security systems, and automatic device shutdowns in case of abnormal tilts. The project involves wiring the components, configuring the EzloPi device to interpret the tilt sensor's output, handle the sensor’s data and trigger appropriate responses.
Welcome to the project demonstration video section. The following video showcases the key aspects of Sense the change in orientation using tilt switch and LED, providing a visual walkthrough of its implementation.
- KY-020 Tilt switch module.
- LED with 100 Ohm Resistor.
From ESP32 to KY-020:
| ESP32 | KY-020 |
| VCC | Vin |
| GND | GND |
| D15 | S (Signal) |
From ESP32 to LED & Resistor:
| ESP32 | LED | Resistor |
| D4 | Anode | - |
| GND | - | 1st Terminal |
| - | Cathode | 2nd Terminal |
4. Interfacing the Tilt Switch Module & LED using the EzloPi Web Flasher
Click Connect
- Set a Device name of your choosing. In our case, we have set it to the Tilt Switch Module.
- Set INPUT GPIO to 15.
- Set Device Subtype to Digital In Switch / Button / Key.
- Set Resistor to PULL DOWN.
- Then Click Apply Button.
- Set a Device name of your choosing. In our case, we set it to the LED.
- Set INPUT GPIO to 4.
- Set Device Subtype to LED.
- Set Resistor to PULL UP.
5. MiOS Web Dashboard
- Now, on the MiOS web dashboard, you will see the tiles of your connected devices as shown above labeled as Tilt Switch Module and LED. Currently, no tilting or changes in orientation is detected by the sensor therefore both tilt sensor and LED tiles show the “OFF” message.
MeshBots:
- After clicking on Create new MeshBot, you will see this now under Automation MeshBot click on EzloPi.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test002.
- Set Node Type to Device.
- Set the Node to Tilt Switch Module.
- Set the Capability to Switch.
- Set the value to True.
- Set Node type to Device.
- Set Controllable to LED.
- Set Capability to switch.
- Set value to true.
- Set value to false.
- Now as seen above, it shows that when the Tilt Switch module gets triggered ON then the LED gets turned ON because of the rules we have set in the meshbot.
6. MiOS App
- On the MiOS mobile dashboard, you will see the tiles of your connected devices as shown above labeled as Tilt Switch Module and LED. Currently, no tilting or changes in orientation is detected by the sensor therefore both tilt sensor and LED tiles show the “OFF” message.
