Make your plants grow with EzloPi!
Scheduled lighting for enhancing plant growth
The project aims to optimize plant growth by implementing a scheduled lighting system using the LED strip with the EzloPi device. By leveraging EzloPi's capabilities, the system will automate the timing for plants, mimicking natural sunlight cycles for optimal photosynthesis. Through precise scheduling, it will ensure consistent and appropriate light conditions, promoting healthier and faster plant growth. Additionally, this system will provide remote monitoring and control options, enabling users to adjust settings conveniently from anywhere using the MiOS smart platform. Overall, the project seeks to revolutionize plant cultivation by harnessing the power of technology for enhanced growth and productivity.
Welcome to the project demonstration video section. The following video showcases the key aspects of Scheduled lighting for enhancing plant growth, providing a visual walkthrough of its implementation.
- XY-MOS, high-power dual MOSFET driver module.
- Mini portable lamp (24 LEDs).
From ESP32 to the MOSFET driver module:
ESP32 | MOSFET driver module |
D5 | Trig |
GND | GND |
From MOSFET driver module to LED Strip:
MOSFET Driver | 24 LEDs mini portable lamp |
OUT+ | 5V |
OUT- | GND |
4. Interfacing the MOSFET driver module using the EzloPi Web Flasher
Click Connect
- Set device name to LED strip.
- Set Device subtype to LED.
- Set OUT GPIO to 4.
- Set Resistor to PULL UP.
- Set the default value to LOW.
- Then Click Apply Button.
5. MiOS Web Dashboard
- After opening the MiOS web dashboard, you will be able to see the tile of your connected device. Currently the tile is OFF, which indicates that the LED strip is OFF and will turn on according to the MeshBot rules which we will configure below.
MeshBots:
- After clicking on Create new MeshBot you will see new options, now under Automation MeshBot click on Local.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test006.
- Set these values in TRIGGER section:
- Set Node Type to Date and Time.
- Set the Node to Custom time and select the time.
- Set the Value Type to Between.
- Set the Start time to 6:00 pm and Day to everyday.
- Click on TRUE.
- Set Node Type to Device.
- Set Controllable Type to LED strip.
- Set the Capability Type to switch.
- Set the Value to true.
- Set Action to immediately.
- Click on FALSE.
- Set the Value to false.
- Now Click the Save button.
- Here in the MiOS web dashboard, you can see that when the set time is reached, the LED strip tile turns on because of the meshbot rules.
6. MiOS App
- After opening the MiOS mobile app dashboard, you will be able to see the tile of your connected device.
- Currently the tile is OFF, which indicates that the AC lamp is OFF.
- Similarly, it can be seen that when the set time is reached, the LED strip tile turns ON indicating that the LED strip is also on. This indicates that the rules we have set in meshbot are working.
