													Light-Up Your Smart Home with RGB customization!
This ESP32 RGB LED example demonstrates the interfacing of an RGB LED module with our versatile and easy-to-use EzloPi device. The RGB LED module can be controlled by the EzloPi device and will allow users to remotely control and customize the color and intensity of the emitted light through the MiOS mobile and web application.
This integration will enable users to incorporate dynamic lighting effects into their home automation setups, enhancing the overall ambiance and functionality of their smart homes.
The following components are required for interfacing the RGB LED module with the EzloPi device:
ESP32 RGB LED Pin Configuration the wiring diagram of ESP32 30 pin is represented as follows:
From ESP32 (30 pins) to the RGB LED module:
The wiring diagram of ESP32 38 pin is also represented as below:
													The following connections are made to complete the circuit setup.
From ESP32 (38 pins) to the RGB LED module:
													Now, select COM Port to which your ESP32 GB LED device is connected. In our case, the COM3 port is used.
Click Connect.
