In this project, we will interface the KY-001 sensor module based on the DS18B20 digital temperature sensor which is a versatile digital sensor capable of accurately measuring temperature in various environments with the EzloPi platform. This will provide the users with an easy and seamless solution for monitoring and controlling the temperature of your smart home, room or office space. This integration allows users to implement temperature-based actions to enhance the smart home experience. The temperature of your smart space can be remotely monitored easily by using the MiOS smart application.
Here, we have demonstrated this project with a DC fan for convenience to showcase the capabilities of the EzloPi smart platform, this can be replaced with an AC fan and 220V source for a practical implementation.
- KY-001 module (DS18B20 digital temperature sensor).
- Single channel relay module.
- 12V DC Fan
The wiring diagram of ESP32 32 pin is represented as follows::
From ESP32 (32 pins) to the temperature sensor module and to the Relay & DC Fan:
- Connect the GND from the ESP32 to the negative (-ve) pin as GND of the DS18B20 module and also to the (-ve) pin as GND of the relay module.
- Connect the 3V3 pin from the ESP32 to the VDD pin of DS18B20 module for voltage supply and middle pin (+ve) of the relay module.
- Connect the D15 pin from the ESP32 to the Signal ‘S’ pin of the DS18B20 module.
- Connect the D5 pin from the ESP32 to the signal ‘S’ pin of the relay module.
- Connect -ve wire from the external DC source terminal block to the COM pin of the relay module.
- Connect NO of the relay module to the -ve terminal of the DC fan.
- Connect +ve wire from the external DC source terminal block to the other +ve terminal of the DC fan.
3. Interfacing the DS18B20 Temperature sensor module using the EzloPi Web Flasher
Click Connect.
- In the Device Configuration, tab click on One Wire..
- A window will open for inputting the following parameters:
- Set a device name of your choosing. In our case, we will set it to DS18B20.
- Set Out GPIO to 15.
- Set Device subtype to DS18B20 Sensor.
- Now Click the Apply button.
- Again in the Device Configuration, tab click on Digital Output.
- Set a device name to Fan.
- Set Device subtype to Relay.
- Set OUT GPIO to 5.
- Set Resistor to PULL UP.
- Set the default value to LOW.
- Then Click Apply Button.
4. MiOS Web Application
- Now, on the MiOS web dashboard, you will be able to see the tiles for the DS18B20 and the fan. These tiles will indicate the status of the fFan depending on the temperature value being detected by the DS18B20 sensor.
MeshBots:
- After clicking on Create new MeshBot you will see this now under Automation MeshBot click on Local.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test002.
- In the trigger tap you can set the TRIGGER for your device and in the ACTION tab you can set the action to be performed based on the trigger which you have created.
- Set Node Type to Device.
- Set the Node to DS18B20.
- Set the Capability to Temp.
- Set the Comparator to Greater (>).
- Set the value to 28.
- Set these values in ACTION section.
- Click on TRUE.
- Set Controllable Type to Fan.
- Set the Capability Type to switch.
- Set the Value to true.
- Set Action to Immediately.
- Now Click on FALSE.
- Set the Value to false.
- Set Action to immediately.
- Now Click the Save button.
- On the MiOS web dashboard, the DS18B20 connected to the EzloPi device is displaying the ambient temperature readings. It is also showing the temperature as 28°C which is our threshold value, the DC fan remains off.
- Here, the dashboard shows that when temperature increases from 28°C to 31°C, the DC fan automatically turns on. Now both our conditions which were set in the meshbot are working.
5. MiOS App
- As we can see above in the MiOS mobile app dashboard, the temperature sensor module tile can be observed, which is showing the current temperature value. The DC Fan will not turn on because the temperature is 28°C, which is our threshold value.
- Now as we can see above, when the temperature goes above our set threshold value, the fan turns on.
