Monitor Your Smart World with EzloPi!
Real-time Light Monitoring using LDR analog sensor
The objective of this project involves interfacing an LDR sensor module with the EzloPi device for real-time light monitoring. The sensor captures ambient light and provides analog values, allowing real-time tracking of light intensity. This integration enables applications such as automated lighting control, energy efficiency optimization, or security systems based on environmental light conditions. The EzloPi device serves as a central hub for processing and managing the sensor data, offering a versatile solution for smart home, office or industrial automation setups.
Welcome to the project demonstration video section. The following video showcases the key aspects of How to make a real time Light Monitoring with LDR Analog Sensor and EzloPi, providing a visual walkthrough of its implementation.
- LM393 Photoresistor module.
From ESP32 to LDR module:
| ESP32 | LDR |
| 3V3 | VCC |
| GND | GND |
| D33 | A0 |
4. Interfacing the LDR sensor module using EzloPi Web Flasher
Click Connect.
- Set a Device name of your choosing. In our case, we set it to LDR.
- Set Device subtype to LDR Sensor (Analog).
- Set OUT GPIO to 33.
- Set Resolution to 10-bit.
- Then Click Apply Button.
5. MiOS App
- After opening the mobile dashboard, you will be able to see the tile of your connected device. The LDR module is currently showing that at the time no amount of light is incident on the sensor so it is showing as ‘0’ value.
- When light is incident on the sensor, it will have analog values proportional to the incident light.
6. MiOS Web Application
- After opening the MiOS web dashboard, you will be able to see the tile of your connected device. The LDR module is currently showing that at the time no amount of light is incident on the sensor so it is showing as ‘0’ value.
- Similarly, when more light is incident on the sensor, LDR’s value will increase.
