Pressure sensing by using Force Sensitive Resistor (FSR402)
Smart sensing and control with EzloPi!
The primary goal of this project is to integrate a Force Sensitive Resistor (FSR402) with the EzloPi device for creating a robust and versatile force-sensing solution. The FSR402, is a pressure-sensitive resistor which can be utilized to capture varying degrees of force applied to a surface. The EzloPi device serves as the central hub for processing and transmitting the FSR data.
Welcome to the project demonstration video section. The following video showcases the key aspects of Smart Pressure measurement using Force Sensitive Resistor FSR402 on EzloPi Platform, providing a visual walkthrough of its implementation.
  • Force Sensitive Resistor FSR402.
  • Resistor 10Kohm.
From ESP32 (30 pins) to the FSR402 & Resistor:
ESP32 FSR402 Resistor
3V3 1st terminal of the sensor VCC
GND – 1st terminal of the resistor
D33 2nd terminal of the sensor 2nd terminal of the resistor
4. Interfacing the Force Sensitive Resistor by using EzloPi Web Flasher
Click Connect.
  1. In the Device Configuration, tab click on Analog Input.
  1. An Analog Input window will open for inputting the following parameters:
  • Set a Device name of your choosing. In our case we set it to FSR402.
  • Set the Device Sub Type to Force Sensitive Resistor (FSR).
  • Set the ADC input pin to 33.
  • Then Click Apply Button.
5. MiOS App
Google PlayApple App Store
  1. After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device. We can see the pressure/force being exerted to the sensor by using the MiOS smart platform.
6. MiOS Web Application
  1. After opening the MiOS web dashboard, you will be able to see the tile of your connected device. We can see the pressure/force being exerted to the sensor by using the MiOS smart platform.
Buy Components
