Discover smart switching with EzloPi!
Precise motion tracking and distance measurement
This project showcases the MPU6050 3-axis accelerometer and gyroscope module alongside the JSN-SR04T ultrasonic sensor to achieve precise motion tracking and distance measurement with the EzloPi device. The MPU6050 enables accurate tracking of movement, orientation, and angular velocity, capturing complex motion patterns and rotations. Complementing this, the JSN-SR04T ultrasonic sensor accurately measures distance, providing reliable readings over longer ranges, even in harsh conditions due to its waterproof design. Together, these sensors offer smart and robust solutions for applications requiring precise movement analysis and obstacle detection, ideal for robotics, navigation, or automation systems.
Welcome to the project demonstration video section. The following video showcases the key aspects of Precise motion tracking and distance measurement, providing a visual walkthrough of its implementation.
- MPU6050 3-axis accelerometer and gyroscope module.
- JSN-SR04T Ultrasonic sensor with analog to digital interface module.
From ESP32 to MPU6050:
| ESP32 | MPU6050 |
| 3V3 | VCC |
| GND | GND |
| D21 | SCL |
| D22 | SDA |
From ESP32 to the JSN SR04T:
| ESP32 | JSN SR04T |
| VIN | VIN |
| GND | GND |
| D5 | ECHO PIN |
| D12 | TRIG PIN |
4. Interfacing the accelerometer & ultrasonic sensor with the EzloPi Web Flasher:
Click Connect
- An I2C window will be opened for inputting the following parameters:
- Set a Device name of your choosing. In our case, we set it to MPU6050.
- Set Device Subtype to MPU6050 Accelerometer and Gyroscope.
- Set the SDA pin to 21.
- Set the SCL pin to 22.
- Tick mark both boxes of Enable pullup.
- Then Click Apply Button.
- An Other window will be opened for inputting the following parameters:
- Set a Device Name of your choosing. In our case, we set it to JSNSR04T.
- Set Device Subtype to JSNSR04T.
- Tick mark the GPIO1 box and set it to 5.
- Tick mark the GPIO1 box and set it to 12.
5. MiOS App
- After opening the MIOS mobile app, you will be able to see the tiles of your connected devices. Here, we have created the scenario of an autonomous vehicle which is operating itself so we have used MPU6050 for acceleration and gyro data with ultrasonic sensor JSN SR04T for distance measurement. The MPU6050 shows the accelerometer and gyro readings of the three axes i.e X,Y and Z regarding the autonomous vehicle and the temperature data of the vehicle whereas the ultrasonic sensor shows the distance among surrounding vehicles to avoid any collision.
6. MiOS Web Dashboard
- After opening the MIOS web dashboard, you will be able to see the tiles of your connected devices. Here, we have created the scenario of an autonomous vehicle which is operating itself so we have used MPU6050 for acceleration and gyro data with ultrasonic sensor JSN SR04T for distance measurement. The MPU6050 shows the accelerometer and gyro readings of the three axes i.e X,Y and Z regarding the autonomous vehicle and the temperature data of the vehicle whereas the ultrasonic sensor shows the distance among surrounding vehicles to avoid any collision.
