PIR sensor with AC Lamp
How to Wire a PIR Sensor with AC Lamp
PIR Sensor Connection: Before moving into this example, it is very important to know about the device registration, provisioning and converting the ESP32 device into an EzloPi device along with knowledge of Web Flasher, MiOS Mobile Application for Android/iOS and the MiOS Web Application.
In this project demonstration, we will show you how to convert an existing project into a smart project using the ESP32 development board. The ESP-based EzloPi device provides the capability to convert your hardware (projects or devices/sensors) into IoT-capable devices
The following user guide will take you through the steps to make existing Arduino projects into smart projects using ESP MCU-based boards. We can get an understanding of this easy process of converting existing projects into smart EzloPi projects by interfacing with the HC-SR505 mini PIR sensor project.
3. Circuit Diagram & Interface - PIR Sensor with Relay Diagram
How to Wire a PIR to a Light
- Generic KG001 HC-SR501 PIR sensor.
- A 5V single-channel relay module for controlling the circuit.
- AC lamp and holder with wires to connect to AC mains.
PIR Sensor Relay Circuit Diagram
The PIR sensor light wiring diagram for ESP32 30 pins is represented as follows:
From ESP32 to Relay module:
- Connect Vin to the VCC of the relay module.
- Connect the GND of the ESP32 to the GND of the relay module.
- Connect D4 to the signal pin on the relay module.
From ESP32 to PIR sensor wiring:
- Connect the D5 pin to the signal pin of the PIR sensor.
- Connect the GND to the GND of the PIR sensor.
- Connect the 3.3V pin of the ESP32 to the VCC pin of the PIR sensor.
From Relay module to AC load:
- Connect the Normally Open (NO) pin to the AC phase wire.
- Connect the Common (COM) pin to Neutral wire
4. Interfacing the AC lamp with relay setup using the EzloPi Web Flasher
Interfacing the PIR motion sensor (HC-SR505) using the EzloPi Web Flasher
- Log in using the credentials that you just set earlier while signing up.
Now, select the COM Port to which your ESP32 device is connected. In our case, the COM3 port is used.
Click Connect.
- A digital output window will open for inputting the following parameters:
- Set a device name of your choosing. In our case, we set it to Light.
- Set Out GPIO to 4.
- Set the default value to low.
- Check the Button Enable option.
- Set INP GPIO to 5.
- Now Click the Apply button.
- After clicking the apply button you can see a table of your settings in the device configuration tab.
5. MiOS App
- As seen above on the MiOS mobile dashboard, the bulb tile is turned OFF indicating that there is no motion being detected by the sensor.
- In the above figure, the device tile and status of the device are indicated whether it is ON or OFF. If anyone comes near the PIR sensor, it will switch on the AC lamp.
6. MiOS Web Application
- After opening the MiOS web dashboard, you will be able to see the tile of your connected device. In the above figure, the status of the device is indicated whether it is ON or OFF. If anyone comes near the PIR sensor, it will switch on the AC lamp.
- As seen above on the web dashboard, the bulb tile is turned OFF indicating that there is no motion being detected.
