Smart motion detection made simpler!
PIR motion sensor with Neon LED strip
This project focuses on interfacing a PIR (Passive Infrared) motion sensor with a flexible neon LED strip using the EzloPi device. The PIR sensor detects motion in its field of view, and upon sensing movement, it triggers the Neon LED strip to illuminate. The project aims to create an automatic lighting system, where the LED strip responds to real-time motion detection. The EzloPi device’s GPIO pins are used to connect and control the PIR sensor and the LED strip, allowing for an energy-efficient and smart lighting solution.
Welcome to the project demonstration video section. The following video showcases the key aspects of PIR motion sensor with Neon LED strip, providing a visual walkthrough of its implementation.
- PIR sensor.
- XY-MOS, high-power dual MOSFET driver module.
- Flexible Neon LED strip.
- 12V Power Supply.
From ESP32 to PIR Sensor:
ESP32 | PIR |
VIN | VDD |
GND | GND |
D13 | SIG |
From ESP32 to the MOSFET driver module:
ESP32 | MOSFET driver module |
D12 | Trig |
GND | GND |
From Power Supply to the MOSFET driver module:
Power Supply | MOSFET driver module |
VCC | SUPPLY+ |
GND | SUPPLY- |
From MOSFET driver module to LED Strip:
MOSFET Driver | LED Strip |
LOAD+ | 5V |
LOAD- | GND |
4. Interfacing the neon LED strip using the EzloPi Web Flasher
Click Connect
- Set a Device name of your choosing. In our case, we have set it to the PIR Motion Sensor.
- Set INPUT GPIO to 13.
- Set Device Subtype to PIR Sensor.
- Set Resistor to PULL DOWN.
- Then Click Apply Button.
- Set a Device name of your choosing. In our case, we set it to the Neon LED.
- Set INPUT GPIO to 12.
- Set Device Subtype to LED.
- Set Resistor to PULL UP.
5. MiOS Web Dashboard
- Now, on the MiOS web dashboard, you will see the tiles of your connected devices as shown above as PIR Motion Sensor and Neon LED.
- Currently, no motion is detected by the sensor therefore both PIR sensor and LED strip tiles show the ‘’No Motion " and "OFF " message respectively.
MeshBots:
- After clicking on Create new MeshBot, you will see this now under Automation MeshBot click on EzloPi.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test005.
- Set Node Type to Device.
- Set the Node to PIR Motion Sensor.
- Set the Capability to Switch.
- Set the value to True.
- Set Node type to Device.
- Set Controllable to Neon LED.
- Set Capability to switch.
- Set value to true.
- Set value to false.
- Now as seen above, it shows that when the PIR Motion sensor gets triggered ON or detects any motion, the Neon LED gets turned ON because of the rules we have set in the meshbot.
6. MiOS App
- On the MiOS mobile dashboard, you will see the tiles of your connected devices as shown above as PIR Motion Sensor and Neon LED.
- Currently, no motion is detected by the sensor therefore both the PIR sensor and LED tiles show the ‘’No Motion " and "OFF " message respectively.
- Now as seen above, it shows that when the PIR Motion sensor gets triggered ON because of some motion then the Neon LED gets turned ON because of the rules we have set in the meshbot.
