Operate various devices with a programmed time delay
In this project, we will interface a relay module and bulb using a single push button module which will perform as a switch. We will use a delay at the output (option of the meshbot) for a predetermined period using the MiOS smart application. For example, In many electronic circuit applications, the delay of a few seconds or minutes has become a crucial requirement for ensuring correct operation of the circuit. Without the specified delay, the circuit could malfunction or even get damaged.
Additionally, by utilizing the EzloPi MeshBots, we can schedule the bulb to turn on at night and turn off in the morning automatically. This project is designed for demonstrating the practical implementation on how to use programmed time delays for various protection and safety applications.
Welcome to the project demonstration video section. The following video showcases the key aspects of How to control smart devices (bulb example) using a programmed delay on EzloPi Platform, providing a visual walkthrough of its implementation.
  • Push button.
  • Relay module.
  • Bulb.
The wiring diagram for ESP32 is represented as below:
From ESP32 to the Push Button:
From ESP32 to the Relay Module:
From Relay Module to the Bulb & 220AC:
4. Interfacing the Relay module using the EzloPi Web Flasher:
Click Connect.
  2. In the Device Configuration, tab click on Digital Input..
  1. A Digital Input window will open for inputting the following parameters:
  • Set device name to Push Button.
  • Set Device subtype to Digital In Switch/Button/Key.
  • Set OUT GPIO to 4.
  • Set Resistor to PULL Down.
  • Set the default value to LOW.
  • Then Click Apply Button.
  1. Again In the Device Configuration, tab click on Digital Output.
  1. A Digital Output window will open for inputting the following parameters:
  • Set device name to Relay.
  • Set Device subtype to Relay.
  • Set OUT GPIO to 5.
  • Set Resistor to PULL UP.
4. MiOS Web Application
  1. After opening the MiOS web dashboard, you will be able to see the tile of your connected device. Currently the tile for the LED is OFF, which indicates that the button and LED are OFF and will turn on according to the MeshBot rules which we will configure below.
MeshBots:
  1. On the right side of the screen under Automation, click on MeshBots.
  1. On meshbot screen, click on Create new MeshBot button present on the top right corner of the screen.
  1. After clicking on Create new MeshBot you will see this now under Automation MeshBot click on Cloud.
  1. On the next screen you will see that we can create a name of our choosing, in this case we write it as Test006.
  1. Set these things in TRIGGER section:
  • Set Node Type to Device.
  • Set the Node to Push Button.
  • Set the Capability Type to Switch.
  • Set the Value to True
  1. Set these values in the TRUE part of the ACTION section.
  • Click on TRUE.
  • Set Controllable Type to Relay.
  • Set the Capability Type to switch.
  • Set the Value to true.
  • Set Action to Delay.
  • Set Seconds to 5.
  1. Set these values in the FALSE part of the ACTION section.
  • Click on False.
  • Set the Value to false.
  • Set Seconds to 5.
  • Now Click the Save button.
  1. Here you can see your saved MeshBot. Now click on Dashboard.
  1. Now, in the MiOS web dashboard, we have delayed the output by 5 seconds in both ON and OFF conditions using meshbot. The relay will turn on after 5 seconds when the button is pushed because of the meshbot rules.
6. MiOS App
Google PlayApple App Store
  1. After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device. Currently the tile for the LED is OFF, which indicates that the button and LED are OFF and will turn on according to the MeshBot rules which we have set with a 5 second delay.
  1. Now, in the MiOS mobile dashboard, we have delayed the output by 5 seconds in both ON and OFF conditions using meshbot. The relay will turn on after 5 seconds when the button is pushed because of the meshbot rules.
Buy Components
