Smart safety and detection with EzloPi!
Obstacle avoidance system with meshbot implementation by using LED and KY-032 sensor
The project aims to create an obstacle avoidance system using the KY-032 infrared sensor and an LED, interfaced with the EzloPi device. The KY-032 sensor detects obstacles in front of it using infrared light reflection. When an obstacle is detected, the sensor sends a signal to the EzloPi device, which triggers the LED to light up, serving as an indicator of the obstacle or an object’s presence. Through this project, users can easily visualize when obstacles are detected, enhancing safety in various applications such as robotics or automation. The system provides a simple yet effective solution for obstacle detection and avoidance, integrating seamlessly with the EzloPi platform for versatile applications.
Welcome to the project demonstration video section. The following video showcases the key aspects of Obstacle avoidance system with meshbot implementation by using LED and KY-032 sensor, providing a visual walkthrough of its implementation.
- KY-032 infrared obstacle avoidance sensor.
- LED with Resistor of 220 Ohms.
From ESP32 (30 pins) to KY-032:
ESP32 | KY-032 |
GND | GND |
D4 | OUT |
From ESP32 to LED & Resistor:
ESP32 | LED | Resistor |
GND | Cathode | - |
D5 | - | 1st terminal |
- | Anode | 2nd terminal |
4. Interfacing the float switch with the EzloPi Web Flasher
Click Connect
- Set a device name of your choosing. In our case we set it to IR Proximity Sensor.
- Set the Input GPIO to 4.
- Set Device Subtype to IR Proximity Sensor.
- Now Click the Apply button.
- Set a device name of your choosing. In our case, we set it to LED.
- Set Device subtype to LED.
- Set OUT GPIO to 5.
- Set Resistor to PULL UP.
- Set the default value to LOW.
5. MiOS Web Dashboard
- Now, on the MiOS web dashboard, you will be able to see the tile for the LED. The tile will indicate the status of the LED depending on the obstacle being detected by the sensor.
MeshBots:
- After clicking on Create new MeshBot you will see new options, now under Automation MeshBot click on Local.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test001.
- Set Node Type to Device.
- Set the Node to IR Proximity Sensor.
- Set the Category to power.
- Set the variables to status.
- Set the Comparator to Equal (==).
- Set the value to true.
- Set these values in the True part of the ACTION section.
- Set the Controllable to LED.
- Set the Capability to switch.
- Set the Value to true.
- Set Action to immediately.
- Set these values in the False part of the ACTION section.
- Set the Value to false.
- Now Click the Save button.
- Here in the MiOS web dashboard, we can see that when the IR proximity sensor gets triggered or detects an object or obstacle. The LED turns on because of the rules we have set in meshbot.
6. MiOS App
- Here, as seen above on the MiOS mobile dashboard, we can see that when the IR proximity sensor gets triggered or detects an object or obstacle. The LED turns on because of the rules we have set in meshbot.
