Object detection and soil monitoring
Innovation redefined with EzloPi
This project integrates object detection and soil monitoring using the EzloPi device. The capacitive soil moisture sensor module measures soil moisture levels, providing crucial data for automated irrigation and soil health monitoring. For object detection, the FC-51 proximity sensor module senses nearby objects, ideal for setting up alerts in restricted zones or detecting the presence of any animal or rodents. The MH-FMD buzzer serves as an alert system, sounding notifications for detected objects or specific soil moisture thresholds, enhancing both environmental monitoring and security applications. This setup offers a versatile solution for smart agriculture and safety systems.
Welcome to the project demonstration video section. The following video showcases the key aspects of Object detection and soil monitoring, providing a visual walkthrough of its implementation.
  • Capacitive soil moisture sensor module.
  • FC-51 proximity sensor module.
  • MH-FMD buzzer.
  • LED with 100 Ohm resistor.
From ESP32 to the Soil Moisture Sensor:
ESP32 Soil Moisture Sensor
3V3 +(VCC)
GND -(GND)
D33 A
From ESP32 to the FC-51 Proximity sensor:
ESP32 FC-51 Proximity Sensor
3V3 VCC
GND GND
D15 OUT
From ESP32 to the LED & Resistor:
ESP32 LED Resistor
GND Cathode -
D5 - Terminal 1
- Anode Terminal 2
From ESP32 to the Buzzer:
ESP32 Buzzer
3V3 VCC
GND GND
D4 I/O
4. Interfacing the Soil Moisture Sensor, Proximity Sensor and buzzer with EzloPi Web Flasher
Click Connect
  2. In the Device Configuration, tab click on Analog Input.
  1. An Analog Input window will open for inputting the following parameters:
  • Set a Device name of your choosing. In our case we set it to Soil Moisture Sensor.
  • Set the Device Subtype to Soil Moisture Sensor.
  • Set the ADC input pin to 33.
  • Set the Resolution to 10-bit.
  • Then Click Apply Button.
  1. In the Device Configuration, tab click on Digital Input.
  1. A Digital Input window will open for inputting the following parameters:
  • Set a Device name of your choosing. In our case, we set it to Proximity Sensor.
  • Set INPUT GPIO to 15.
  • Set Device subtype to Proximity Sensor.
  • Set Resistor to PULL DOWN.
  1. In the Device Configuration, tab click on Digital Output
  1. A Digital Output window will open for inputting the following parameters:
  • Set a Device name of your choosing. In our case, we set it to Buzzer Alarm.
  • Set Device subtype to LED.
  • Set OUT GPIO to 4.
  • Set Resistor to PULL UP.
  1. In the Device Configuration, tab click on Digital Output.
  • Set a Device name of your choosing. In our case, we set it to LED Alarm.
  • Set OUT GPIO to 5.
5. MiOS Web Dashboard
  1. On the MiOS web dashboard, you will be able to see the tiles for the soil moisture sensor, proximity sensor, buzzer alarm and LED alarm. The LED and buzzer alarms will indicate the status of soil moisture and proximity sensor values respectively.
MeshBots:
  1. On the left side of the screen under Automation, click on MeshBots.
  2. On meshbot screen, click on Create new MeshBot button present on the top right corner of the screen.
  3. After clicking on Create new MeshBot, you will see this now under Automation MeshBot click on Cloud.
  1. On the next screen you will see that we can create a name of our choosing, in this case we write it as Test011.
  1. Set these things in TRIGGER section:
  • Set Node Type to Device.
  • Set the Node to Soil Moisture Sensor.
  • Set the Capability to parent_abstract.
  • Set the variables to uuid.
  • Set the Comparator to Less (<).
  • Set Value Type to value.
  • Set the value to 25.
  1. Set these values in the TRUE part of the ACTION section.
  • Set Controllable Type to Device.
  • Set the Controllable to LED Alarm.
  • Set the Capability to power_command.
  • Set the Value Type to set.
  • Set the Value to true.
  • Now Click the Save button.
  1. Again Create new meshbot by clicking on Create new MeshBot you will see this now under Automation MeshBot click on Cloud.
  1. On the next screen you will see that we can create a name of our choosing, in this case we write it as Test012.
  • Set the Node to Proximity Sensor.
  • Set the Capability to motion_sensor.
  • Set the variables to status.
  • Set the Comparator to Equal(==).
  • Set the value to true.
  • Set the Controllable to Buzzer Alarm.
  1. Here you can see your saved MeshBot. Now click on Dashboard.
  1. In the MiOS web dashboard, you can see that when the soil moisture sensor detects a moisture value of less than 25, the LED alarm is turned ON because of the rules we have set in the meshbot.
  1. Here in the above scenario, the proximity sensor detects movement which is unauthorized and can be harmful to our crops or plants therefore the buzzer alarm is turned ON because of the rules we have set in the meshbot.
6. MiOS App
Google PlayApple App Store
  1. In the MiOS mobile app, you can see that when the soil moisture sensor detects a moisture value of less than 25, the LED alarm is turned ON because of the rules we have set in the meshbot.
Buy Components
