EzloPi Meets FC-28 for Ultimate Plant Care!
Multiple Soil Moisture Sensor
ESP32 Soil Moisture Sensor: ESP32 Soil Moisture Sensor: Before moving into this example, it is very important to know about the device registration, provisioning and converting the ESP32 device into an EzloPi device along with knowledge of Web Flasher, MiOS Mobile Application for Android/iOS and the MiOS Web Application.
In this project, we will show you how to harness the power of the EzloPi platform to create an intelligent plant care system by interfacing not one, but two FC-28 soil moisture sensor modules.
By combining these components, you can ensure your plants receive the optimal level of hydration, leading to healthier and happier greenery. The moisture can then be monitored using the MiOS app to stay up-to-date with the moisture levels of the soils. Through this project, you can optimize your watering schedule based on accurate moisture readings, promoting water efficiency and preventing over or under-watering.
2. Project Demonstration Video - ESP32 Soil Moisture Sensor - ESP32 Soil Moisture Sensor
Welcome to the project demonstration video section. The following video showcases the key aspects of Multiple Soil Moisture Sensor, providing a visual walkthrough of its implementation.
3. Circuit Diagram & Interface - Soil Moisture Sensor - Soil Moisture Sensor
- FC-28 Soil moisture sensor
How to Connect Soil Moisture Sensor to ESP32 the following connections are made in order to complete the entire circuit setup.
From ESP32 to the Soil Moisture Sensor Module:
- Connect the 3V3 pin from ESP32 to the VCC terminal of both the moisture sensor modules.
- Connect GND from the ESP32 to the GND pin on both the moisture sensor modules.
- Connect D33 from the ESP to the signal (A0) pin of one soil moisture sensor and D32 of ESP32 to the second soil moisture sensor.
4. Interfacing the FC-28 Soil moisture sensors using EzloPi Web Flasher
Click Connect.
- If you are new to this and it's your first time configuring, select Create new Device ID. nter Wifi SSID and Wifi Password.
Interfacing the first Soil moisture sensor with EzloPi Web Flasher:
- Set a device name of your choosing. In our case, we set it to Soil Moisture Sensor.
- Set device Subtype to Soil Moisture Sensor.
- Set the ADC input pin to 32.
- Set the Resolution to 10-bit
- Now Click the Apply button.
Interfacing the second Soil moisture sensor with EzloPi Web Flasher:
- Set the ADC input pin to 33.
4. MiOS App
- After some time, a popup will appear saying Device Flashed Successfully! ! This means that your device has been set up successfully.
5. MiOS App
- After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device. In our case, we can see two tiles labeled as “Soil Moisture Sensor” for the two moisture sensors interfaced.
- We can monitor the soil moisture of different soils by connecting multiple soil moisture sensors. Here we are using two ESP32 soil moisture sensors, however we can use more than two sensors depending on the requirement or application.
6. MiOS Web Application
- We can monitor the soil moisture of different soils by connecting multiple soil moisture sensors. Here we are using two ESP32 soil moisture sensors, however we can use more than two sensors as shown on the web dashboard depending on the requirement or application.
