MQ8 Hydrogen Gas Sensor
In this project, we will see how to interface an MQ8 hydrogen gas sensor with an EzloPi device to monitor the concentration levels in our environment.
The MQ8 hydrogen gas sensor, when integrated with the EzloPi device, provides an efficient solution for detecting hydrogen gas (H2) in various settings. This unique combination empowers users to enhance safety, monitor gas leaks, and create intelligent controls to automate actions, such as activating ventilation systems, shutting off gas supplies, or triggering alarms in the event of high hydrogen gas concentrations.
The MQ8 is suitable for a wide range of applications, including home automation, industrial safety, laboratories, and hydrogen-powered vehicle charging stations.
  • MQ8 hydrogen Gas Sensor.
From ESP32 to the MQ8 Hydrogen Gas Sensor
  • Connect Vin from the ESP32 to the VCC of the sensor.
  • Connect GND from the ESP32 to the GND pin of the sensor.
  • Connect D33 from the ESP32 to the A0 Pin of the sensor.
3. Interfacing the MQ8 Hydrogen Gas Sensor using EzloPi Web Flasher
Touch Sensor Digital Module
Click Connect.
  • Set a device name of your choosing. In our case, we set it to MQ8.
  • Set Device subtype to MQ8 Gas sensor module.
  • Check the box of GPIO 1.
  • Set OUT GPIO 1 to 33.
  • Now Click the Apply button.
4. MiOS App
Google PlayApple App Store
MiOS App
MiOS
  1. After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device. The MQ8 Hydrogen gas sensor module tile reflects the hydrogen gas levels in the environment.
5. MiOS Web Application
Login to MiOS App
  1. After opening the MiOS web dashboard, you will be able to see the tile of your connected device. The MQ8 Hydrogen gas sensor tile reflects the hydrogen gas levels in the environment.
Buy Components
