MQ4 Methane Gas Sensor
1. About this example – MQ4 Sensor
The following example demonstrates how the MQ4 Methane Gas Sensor is interfaced with the EzloPi device and how it is implemented.
The MQ4 Methane Gas Sensor is a widely used gas detection module designed to detect methane (CH4) gas in the environment. It operates based on the principle of gas resistance, where the sensor’s resistance changes in the presence of methane gas, allowing for gas concentration measurement which can be remotely monitored using the MiOS mobile and web application.
2. Circuit Diagram & Interface – MQ4 Gas Sensor
  • MQ4 Methane Gas Sensor Module.
The wiring diagram for ESP32 30 pin is represented as follows:
MQ4 Methane Gas Sensor Wiring
MQ4 Gas Sensor Breadboard
From ESP32 to the MQ4 Gas Sensor
  • Connect Vin from the ESP32 to the sensor’s VCC.
  • Connect the GND from the ESP32 to the GND pin of the sensor.
  • Connect D33 from the ESP32 to the A0 Pin of the sensor.
3. Interfacing the MQ4 Gas sensor module using EzloPi Web Flasher
Touch Sensor Digital Module
  1. Log in using the credentials that you just se earlier while signing up.
MQ4 Sensor
MQ4 Sensor Serial Port
  1. Now, select the COM Port to which your ESP32 device is connected. In our case, the COM3 port is used.
Click Connect.
MQ4 Sensor Device Status
MQ4 Sensor Device Configuration
  • Set a device name of your choosing. In our case, we set it to MQ4.
  • Set Device subtype to MQ4 Methane Gas Sensor.
  • Check the box of GPIO 1.
  • Set OUT GPIO 1 to 33.
  • Now Click the Apply button.
  • After clicking the apply button you can see a table of your settings in the device configuration tab.
MQ4 Sensor - Ready to Flash
Flashing in Progress
Device Flashed
4. MiOS App
Google PlayApple App Store
MiOS App
MiOS
Select a Location
  1. After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device. The MQ4 Methane gas sensor tile reflects the concentration readings of the Methane gas being detected by the sensor at that moment.
5. MiOS Web Application
Login to MiOS App
  1. After opening the MiOS web dashboard, you see the tile of your connected device. The MQ4 Methane gas sensor tile will reflect the concentration readings of the Methane gas.
Buy Components
