MQ3 Alcohol Sensor
MQ3 Alcohol Sensor
Cheers to EzloPi Innovation!
Top Projects
MQ3 Alcohol Sensor
The following example showcases how we can interface a touch sensor and buzzer with the EzloPi device and use it as a touch switch.
This setup allows you to use a touch sensor to trigger the buzzer, providing audible feedback in response to a touch event. We can expand upon this foundation to create more complex and interactive applications with our EzloPi device.
  • TTP223B Capacitive Touch Sensor module.
  • Buzzer.
From ESP32 to the MQ3 Alcohol Sensor:
  • Connect Vin from the ESP32 to the VCC of the sensor.
  • Connect the GND from the ESP32 to the GND pin of the sensor.
  • Connect D33 from the ESP32 to the A0 Pin of the sensor.
3. Interfacing the MQ3 Alcohol sensor module using EzloPi Web Flasher
Touch Sensor Digital Module
  1. Log in using the credentials that you just set earlier while signing up.
  1. Now, select the COM Port to which your ESP32 device is connected. In our case, the COM3 port is used.
Click Connect.
  • Set a device name of your choosing. In our case, we set it to MQ3.
  • Set Device subtype to MQ3 Alcohol Sensor.
  • Check the box of GPIO 1.
  • Set OUT GPIO 1 to 33.
  • Now Click the Apply button.
  • After clicking the apply button you can see a table of your settings in the device configuration tab.
4. MiOS App
Google PlayApple App Store
MiOS App
MiOS
  1. After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device. The MQ3 Alcohol sensor tile reflects the concentration readings of the alcohol vapors being detected by the sensor at that moment.
5. MiOS Web Application
Login to MiOS App
  1. After opening the MiOS web dashboard, you see the tile of your connected device. The MQ3 Alcohol sensor tile will reflect the concentration readings of the alcohol vapours in the environment.
Buy Components
