MQ2 LPG Gas Sensor
The following example demonstrates how the MQ2 LPG Gas Sensor is interfaced with the EzloPi device and how it is implemented.
The MQ2 LPG Gas Sensor is a popular gas detection module widely used in electronic projects and home automation systems. It is capable of detecting various gases, including LPG (liquefied petroleum gas), propane, methane, and other flammable gases. We can set the threshold values for gas concentration levels that trigger alerts or actions on the EzloPi device.
By interfacing the MQ2 LPG Gas Sensor with the EzloPi device, you can create a smart gas detection and safety system that helps protect against the dangers of gas leaks in various environments, from homes and offices to industrial facilities.
  • MQ2 LPG Gas Sensor.
The wiring diagram for the ESP32 30-pin is represented below:
The following connections are made to complete the entire circuit setup.
From ESP32 to the MQ2 LPG Sensor:
  • Connect Vin from the ESP32 to the VCC of the sensor.
  • Connect the GND from the ESP32 to the GND pin of the sensor.
  • Connect D33 from the ESP32 to the A0 Pin of the sensor.
3. Interfacing the MQ2 Gas sensor module using EzloPi Web Flasher
Touch Sensor Digital Module
  1. Log in using the credentials that you just set earlier while signing up.
EzloPi Device not Connected
PCI Serial Port
  1. Now, select the COM Port to which your ESP32 device is connected. In our case, the COM3 port is used.
Click Connect.
Connected Device Status
  • Set a device name of your choosing. In our case, we set it to MQ2.
  • Set Device subtype to MQ2 LPG Gas Sensor.
  • Check the box of GPIO 1.
  • Set OUT GPIO 1 to 33.
  • Now Click the Apply button.
  • After clicking the apply button, you can see a table of your settings in the device configuration tab.
Connected to a Serial Port
Flashing in Progress
Configuration Selection
4. MiOS App
Google PlayApple App Store
MiOS App
MiOS
Select a Location
MQ2 LPG Gas Sensor
  1. After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device. The MQ2 LPG Gas Sensor tile reflects the concentration readings of the LPG gas being detected by the sensor at that moment.
5. MiOS Web Application
Login to MiOS App
MiOS Dashboard
  1. After opening the MiOS web dashboard, you see the tile of your connected device. The MQ2 LPG Gas Sensor tile will reflect the concentration readings of the LPG gas.
Buy Components
