MQ135 Ammonia Gas Sensor
1. About this example – MQ135 ESP32
In this project, we will see how to interface an MQ135 gas sensor with an EzloPi device to monitor indoor air quality.
The MQ135 NH3 gas sensor, when integrated with the EzloPi device, provides an efficient and reliable solution for monitoring ammonia (NH3) levels to protect your environment from potential hazards and bringing safety and environmental awareness to the forefront of your IoT projects. This powerful combination makes it ideal for applications such as indoor air quality management, industrial safety, and environmental monitoring.
  • MQ135 ESP32 as an EzloPi smart device.
  • MQ135 Gas sensor module.
The wiring diagram for the MQ135 ESP32 30 pin is represented as below:
MQ135 Ammonia Gas Sensor Wiring Diagram
MQ135 Ammonia Gas Sensor Breadboard
From ESP32 to the MQ135 Gas Sensor module:
  • Connect Vin from the ESP32 to the VCC of the sensor.
  • Connect GND from the ESP32 to the GND pin of the sensor.
  • Connect D33 from the ESP32 to the A0 Pin of the sensor.
3. Interfacing the MQ135 Ammonia Gas Sensor using EzloPi Web Flasher
Touch Sensor Digital Module
Device Status
PCI Serial Port
  1. Now, select COM Port to which your MQ135 ESP32 device is connected. In our case, the COM3 port is used.
Click Connect.
Connect to Serial Port
  • Set a device name of your choosing. In our case, we set it to MQ135 ESP32.
  • Set Device subtype to MQ135 Gas sensor module.
  • Check the box of GPIO 1.
  • Set OUT GPIO 1 to 33.
  • Now Click the Apply button.
Ready to Flash
Switch to Terminal
Device Flashed Successfully
4. MiOS App
Google PlayApple App Store
MiOS App
MiOS
Select a Location
Gas Sensor
  1. After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device. The MQ135 NH3 gas sensor module tile reflects the quality of air by measuring the NH3 concentration present in the environment.
5. MiOS Web Application
Login to MiOS App
Dynamic Dashboard
  1. After opening the MiOS web dashboard, you see the tile of your connected device. You will be able to see the tile of your connected device. The MQ135 NH3 gas sensor module tile reflects the quality of air by measuring the NH3 concentration present in the environment.
Buy Components
