Smart projects to make life easier
MPU6050 tilt demonstration with LEDs
The MPU6050 tilt demonstration showcases real-time tilt detection using the MPU6050 3-axis accelerometer and gyroscope module, integrated with the EzloPi device. Three LEDs are employed to visually indicate tilt in different axes: X, Y, and Z. When the module detects a tilt beyond a predefined threshold, the corresponding LED illuminates, providing an intuitive understanding of motion and orientation. This project is ideal for learning about motion sensors, accelerometer data processing, and interactive feedback systems. It highlights the EzloPi’s capability to interface with sensors and LEDs for dynamic applications.
- MPU6050 3-axis accelerometer and gyroscope module..
- 3 LEDs with 120 Ohm resistors.
From ESP32 to the MPU6050:
| ESP32 | MPU6050 |
| 3V3 | 3V3 |
| GND | GND |
| D21 | SDA |
| D22 | SCL |
From ESP32 to the LED1 & Resistor1:
| ESP32 | LED1 | Resistor1 |
| D12 | - | Terminal 1 |
| GND | Cathode | - |
| - | Anode | Terminal 2 |
From ESP32 to the LED2 & Resistor2:
| ESP32 | LED2 | Resistor2 |
| D13 | - | Terminal 1 |
| GND | Cathode | - |
From ESP32 to the LED3 & Resistor3:
| ESP32 | LED3 | Resistor3 |
| D14 | - | Terminal 1 |
| GND | Cathode | - |
4. Interfacing the MPU6050 & 3 LEDs with the EzloPi Web Flasher:
Click Connect
- An I2C Input window will be opened for inputting the following parameters:
- Set a Device name of your choosing. In our case, we set it to MPU6050.
- Set Device Subtype to GY61 3-Axis Accelerometer.
- Set the Slave address to 104.
- Set the SDA pin to 21.
- Set the SCL pin to 22.
- Tick mark both the boxes of Enable pullup.
- Then Click Apply Button.
- Set a Device name of your choosing. In our case, we set it to the LED 1.
- Set Device Subtype to LED.
- Set the OUT GPIO to 12.
- In the Device Configuration, tab click on Digital Output
- Set a Device name of your choosing. In our case, we set it to the LED 2.
- Set the OUT GPIO to 13.
- Set a Device name of your choosing. In our case, we set it to the LED 3.
- Set the OUT GPIO to 14.
5. MiOS Web Dashboard
- On the MiOS web dashboard, we can see the values of X-axis, Y-axis and Z-axis and the Gyro data of X, Y and Z Axes, also the tiles of 3 LEDs.
MeshBots:
- After clicking on Create new MeshBot, you will see this now under Automation MeshBot click on Cloud.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test011.
- Set Node Type to Device.
- Set the Node to MPU6050_Acc_x.
- Set the Capability to parent_abstract.
- Set the variables to uuid.
- Set the Comparator to Greater (>).
- Set the value to 0.
- Set the Controllable to LED 1.
- Set the Capability to power_command.
- Set the Value Type to set.
- Set the value to true.
- Here, you can see your saved MeshBot. Now again click on Create new Meshbot.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test012.
- Set the Comparator to Equal (==).
- Set the Controllable to LED 2.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test013.
- Set the Comparator to Less (<).
- Set the Controllable to LED 3.
- Now Click the Save button.
- Here, you can see your saved MeshBot. Now click on Dashboard.
- Now, in the MiOS web dashboard, we can see the values of X-Axis, Y-axis and Z-axis and the Gyro data of X, Y and Z Axes, also the tiles of 3 LEDs. We want to indicate only the X-axis level through the LEDs. Here when the X-axis value goes above 0 then LED 1 gets turned ON due to our meshbot settings.
- Now in the above picture, we can see that the value of the X-axis is stable at 0 then the LED 2 turns ON because of our setting of meshbot.
- Here in this picture, we can see that the value of the X-axis goes below 0 then the LED 3 turns ON because of our setting of meshbot.
6. MiOS App
- Here, as seen above on the MiOS mobile dashboard, we can see the values of Y-axis and Z-axis and the Gyro data of X, Y and Z Axes, also the tiles of 3 LEDs. We want to indicate only the X-axis level through the LEDs. So here when the Z-axis value goes above 0 then LED 1 gets turned ON due to our meshbot settings.
