Movement and IR radiation detection
This project leverages the ADXL345 3-axis accelerometer and PIR motion sensor to detect physical movement and IR radiations, respectively interfaced with the EzloPi device. The ADXL345 captures precise motion data in three dimensions, enabling the monitoring of dynamic or static movements. Complementing this, the PIR motion sensor identifies IR radiation changes, signaling the presence of moving objects or movement within its range. Together, these sensors create a versatile system for applications such as security, activity tracking, and automation. The EzloPi device serves as the main hub for processing sensor inputs for real-time actions or notifications.
  • ADXL345 3-axis accelerometer.
  • PIR Motion sensor.
From ESP32 to the ADXL345:
ESP32ADXL345
3V3VCC
GNDGND
D21SDA
D22SCL
From ESP32 to the PIR Sensor:
ESP32PIR Sensor
VINVDD
GNDGND
D13SIG
4. Interfacing the ADXL345 3-Axis Accelerometer with PIR Sensor with the EzloPi Web Flasher
Click Connect
  2. In the Device Configuration, tab click on I2C.
  1. An I2C window will be opened for inputting the following parameters:
  • Set the Device name of your choosing. In our case, we set it to ADXL345.
  • Set the Device Subtype to ADXL345 3-Axis Accelerometer.
  • Set the Slave Address to 89.
  • Set the SDA pin to 21.
  • Set the SCL pin to 22.
  • Tick mark the Button Enable Box.
  • Then Click Apply Button.
  1. In the Device Configuration, tab click on Digital Input.
  1. A Digital Input window will be opened for inputting the following parameters:
  • Set the Device name of your choosing. In our case, we set it to PIR Sensor.
  • Set the INPUT GPIO to 13.
  • Set the Device Subtype to PIR Sensor.
  • Set the Resistor to PULL DOWN
5. MiOS Web Dashboard
  1. On the MiOS web dashboard, the tiles are displayed for the ADXL345 and the PIR sensor. We are using these sensors to monitor movements. When ADXL345 gives a certain value and when the PIR motion sensor receives some input then it will give a notification about it.
MeshBots:
  1. On the left side of the screen under Automation, click on MeshBots.
  2. On meshbot screen, click on Create new MeshBot button present on the top right corner of the screen.
  3. After clicking on Create new MeshBot, you will see this now under Notification MeshBot click on Create.
  1. On the next screen you will see that we can create a name of our choosing, in this case we write it as Test014.
  1. Set these things in TRIGGER section:
  • Set Node Type to Device.
  • Set the Node to ADXL345_acc_x.
  • Set the Capability to parent_abstract.
  • Set the Variables to uuid.
  • Set the Comparator to Greater (>).
  • Set the Value Type to value.
  • Set the Value to 2.5.
  1. Set these values in the ACTION section.
  • Set Controllable Type to Notification.
  • Set the User to Your user account .
  • Set the Channels to email,push.
  • Set the Subject to Detect Movement.
  • Write the suitable Message body that you want to receive in your email. As you can see, we write, Both physical and infrared movement are detected.
  • After clicking the apply button you can see a table of your setting in the Current configuration tab.
  1. Here you can see your saved MeshBot. Now click on Dashboard.
  1. Now as shown above, when the ADXL345 accelerometer gets a certain value and the PIR sensor detects motion or an object then we get a notification notifying us about the detected movements.
6. MiOS App
Google PlayApple App Store
  1. After opening the dashboard, you will be able to see the tile of your connected device.
Buy Components
